edit:
I scaled the question down to a more understandable size, thanks for your input.
please see the 4th post.
Initial post:
Hi All,
I started a sketch, which is working 100% for me, but i feel i can simplyfy the code alot.
I feel i need to use to may variables and i need to write to much duplicate code to create another button.
I think the function "DigitalUserInput_stopPoll" is sort of completly redundant, but somehow i was not able to pass data directly into the "real" button checking function. At this specific point i would like some guidence.
the goal of this sketch is to create an button library/class that will later on drive multiple stepperdrivers.
I want to avoid any delay functions because this would prevent my steppers later on to run smooth.
The following is just a setup of a approach to create an flexible button library that will easily setup a button every time.
Button, can be toggle, momentary long pressed and later maybe double pressed(which i don't care for personally)
I understand there are ready library's available, but i see this as an exercise.
disclaimer, i have about a week or 2 programming experience, but a life time of logic thinking.
Please if you see very unlogical approaches i would be happy if they will be pointed out. I really feel like why! did i not started doing this earlier, this is fun!
I understand this code should be jarred in some sort of class later on but i'm not there yet, or actually i would love to understand that!, maybe you boys and girls can help me out.
debouncing is basically done by slowing down the program, this is now a delay, but otherwise could be all the stepper motor calls and other calculations.
For this to become a class, maybe i should add a timed debouncing, something like, only operate when 5millis has been passed since last poll.
int DigitalUserInput_stopPin = 10;//digital input on pin 10
int DigitalUserInput_stop[5] = {DigitalUserInput_stopPin, 0, 1, 1000, 0};//sets array for pushbutton STOP
// place 0 = pin,
// 1 = 0 = state of button, 0 = off, 1 = on, 2 = undefined, 3 = is pressed longer than "holdtime", 4 = pressing the button after holdtime(state 3).by default should be 0
// 2 = type = 0 for momentairy button, 1 = for switch on off button, 2 = for a toggle switch(cancells longpress options)
// 3 = holdtime = the time before a long pressed is registered in millisecond 1000 is 1 sec.
// 4 = reset = to let the program know if the button is cleared for a next step.
unsigned long DigitalUserInput_stopTimeStamp = 0;//defines a variable for a timestamp. i wanted this in teh array, but the unsigned long conflicted with the INT's.
unsigned long currentMillis = 0;// declares the reference timer
int pin = 0;//variable later used by the "checkDigitalUserInput" function
int state = 0;//variable later used by the "checkDigitalUserInput" function
int type = 0;//variable later used by the "checkDigitalUserInput" function
unsigned long Stime = 0;//variable later used by the "checkDigitalUserInput" function
unsigned long Etime = 0;//variable later used by the "checkDigitalUserInput" function
int holdtime = 0;//variable later used by the "checkDigitalUserInput" function
int reset = 0;//variable later used by the "checkDigitalUserInput" function
int timSerial = 0;//variable used to have a timed serial output rather than delaying the program.
pinMode(DigitalUserInput_stopPin, INPUT);//declares pin 8 to be a stopPin
void DigitalUserInput_stopPoll(){
checkDigitalUserInput(DigitalUserInput_stop[0], DigitalUserInput_stop[1], DigitalUserInput_stop[2], DigitalUserInput_stop[3], DigitalUserInput_stop[4], DigitalUserInput_stopTimeStamp);
DigitalUserInput_stop[0] = pin;
DigitalUserInput_stop[1] = state;
DigitalUserInput_stop[2] = type;
DigitalUserInput_stop[3] = holdtime;
DigitalUserInput_stop[4] = reset;
DigitalUserInput_stopTimeStamp = Stime;
Stime = 0;
void checkDigitalUserInput(int pinF, int stateF, int typeF, int holdtimeF, int resetF, unsigned long StimeF)
currentMillis = millis();
//Serial.println(pinF);
pin = pinF;//this gives me the possibility to rember the old state
state = stateF;//this gives me the possibility to rember the old state
type = typeF;//this gives me the possibility to rember the old state
Stime = StimeF;//this gives me the possibility to rember the old state
reset = resetF;//this gives me the possibility to rember the old state
if(state == 4){// when pressed after 3, state 4 occurs, only needed once. so clear to state unpressed
state = 0;
reset = 0;
if(typeF == 0 || typeF == 2)//if a momentairy switch/button or toggle switch, do this
if(digitalRead(pinF) == HIGH && stateF == 0 && resetF == 0)//reset is a variable that tells if the button is "ready" for a new state.
if(typeF == 0){Stime = currentMillis;}//button is pressed, change its state, start the timer, here hardware toggle switches get excluded from timing.
state = 1;
reset = 1;
Etime = 0;
if(digitalRead(pinF) == LOW && stateF == 1 && resetF == 1)//button released after being pressed
//Etime = (currentMillis - Stime);// no need for this as the timer will run aslong as the button is NOT released.
state = 0;
reset = 0;//sets the button to available
Stime = 0;//clears start time
if(typeF == 1)//if the momentairy button should act as a switch, (press once for on, press again for off) do this:
if(digitalRead(pinF) == HIGH && resetF == 0)
Stime = currentMillis;//start timer
reset = 1;//reset high(button busy)
if(stateF == 0)
state = 1;
if(stateF == 1)//if state is high
state = 0;//set o
if(digitalRead(pinF) == LOW && resetF == 1)//if low and reset is high, theoretically this part should come first.....
//Etime = (currentMillis - Stime);//print time
reset = 0;// make button ready for a state change
Stime = 0;//stop timing, button has been released.
if(Stime != 0)// this is to prevent to set Etime as currentMillis, which always will be bigger than the proposed holdTime
Etime = (currentMillis - Stime);//setting an elapsed time if any.
if(Etime > holdtimeF)//if time is larger than hold time
state = 3;//set 3
Stime = 0;//clear starttime
reset = 1;//sets reset high as to prevent it from looping the timer again.
Etime = 0;//clears time bank
if(digitalRead(pinF) == LOW && stateF == 3 && resetF == 1)// if button released clear the button by reset = 0
//Stime = currentMillis;
//state = 3;
reset = 0;
//Etime = 0;
if(digitalRead(pinF) == HIGH && stateF == 3 && resetF == 0)
Stime = 0;// this should not result in a long press again.
state = 4;// will be reset every time this complete function is called, so 1 time use only :)
reset = 1;
//Etime = 0;
pin = pinF;// give back variables, is this nescesairy, probably not
type = typeF;// give back variables, is this nescesairy, probably not
holdtime = holdtimeF;// give back variables, is this nescesairy, probably not
DigitalUserInput_stopPoll();//check status
delay(100);//dont kill the serial monitor
Serial.println(DigitalUserInput_stop[0]);//show pin
Serial.println(DigitalUserInput_stop[1]);//show state
Serial.println(DigitalUserInput_stop[2]);// show type
Serial.println(DigitalUserInput_stop[3]);//show holdtime
Serial.println(DigitalUserInput_stop[4]);//show reset
Serial.println(DigitalUserInput_stopTimeStamp);//show timestamp
Thank you!
