ok, so I was trying to build a serial command system when I started getting the error:
Arduino: 1.7.6 (Windows 8.1), Board: "Arduino Uno"
sketch_aug21a.ino: In function 'void loop()':
sketch_aug21a.ino:37:11: error: cannot convert 'String' to 'char' in assignment
Error compiling.
enabled in File > Preferences.
I have the two following lines of code in my program:
cmd[15] = (Serial.readStringUntil('.'));
const int lgcmd = 15;
char cmd[lgcmd];
Can someone help me with this problem? I'm really confused with it.
Please help us by posting the whole program, not just the snippet that you think is causing the problem.
The .readStringUntil() command returns a sequence of characters and you are strying to put them all in one location - cmd[15].
If you want to fill the whole cmd array, you would use
cmd = Serial.readUntil('.');
But you might have other problems. If you declare cmd as char cmd[15], index 15 does not exist.
but it does not matter since char cmd[lgcmd] attempts to create a whole new array, anyway.
You are trying to treat a C++ String object as if it is a C string array.
The C++ String is a C string with packaging for people too lazy to learn and use C strings. You're not supposed to need to get at the actual data in a String.
C++ Strings are wasteful of both memory and cycles. Microcontrollers have less of both than PC's.
Best solution is to ditch using C++ Strings in such small environments and code closer to the metal.
UPDATE:
I did some editing based off of KeithRB 's reply. However, I still am getting a similar error.
I also posted (below) the full code, and enabled "verbose output".
Code:
#include <Servo.h>
const int prop = 3;
const int steer = 2;
const int boad = 38400;
char cmd[6];
int incmd = 0;
Serial.begin(boad);
Serial.println("Serial communications have been opened.");
Serial.println("---------------------------------------");
Serial.println("Serial connection established. Boad: ");
Serial.print(boad);
pinMode(prop, OUTPUT);
//confirmation of setup:
Serial.println("-------------Now Looping...------------");
Serial.println("Ready for command. Send /help. for help");
cmd = Serial.readStringUntil('.');
Error:
Using library Servo in folder: C:\Program Files (x86)\Arduino\libraries\Servo
C:\Program Files (x86)\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10706 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Program Files (x86)\Arduino\libraries\Servo\src C:\Users\Jacob\AppData\Local\Temp\build1086056094383448326.tmp\sketch_aug21a.cpp -o C:\Users\Jacob\AppData\Local\Temp\build1086056094383448326.tmp\sketch_aug21a.cpp.o
sketch_aug21a.ino:27:7: error: incompatible types in assignment of 'String' to 'char [6]'
Error compiling.
Not sure what you are trying to do, but below is some delimited servo test code.
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod; // create servo object to control a servo
//myservoa.writeMicroseconds(1500); //set initial servo position if desired
myservoa.attach(6); //the pin for the servoa control
myservob.attach(7); //the pin for the servob control
myservoc.attach(8); //the pin for the servoc control
myservod.attach(9); //the pin for the servod control
Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
//expect single strings like 700a, or 1500c, or 2000d,
//or like 30c, or 90a, or 180d,
//or combined like 30c,180b,70a,120d,
if (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
if (c == ',') {
if (readString.length() >1) {
Serial.println(readString); //prints string to serial port out
int n = readString.toInt(); //convert readString into a number
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
if(readString.indexOf('a') >0) myservoa.write(n);
if(readString.indexOf('b') >0) myservob.write(n);
if(readString.indexOf('c') >0) myservoc.write(n);
if(readString.indexOf('d') >0) myservod.write(n);
readString=""; //clears variable for new input
else {
readString += c; //makes the string readString
The error seems quite explicit to me.
cmd is an array of chars and you are trying to assign a String to it.
I suggest that you read each character as it becomes available and save it in the cmd array until you receive a full stop, but make sure that you only receive 6 characters at most or you will be in trouble. If you want to use cmd as C style string with a null terminator then you will need to add that yourself and ensure that you only receive 5 characters before the full stop.
UPDATE: THE ISSUE HAS BEEN RESOLVED!
The new code compiled successfully. I had tried 'string cmd;' but, it seems I wasted the time of ~100 people over the difference between 's' and 'S'.
Thank you, zoomkat, for the example.
New code
#include <Servo.h>
const int prop = 3;
const int boad = 9600;
String cmd;
int incmd = 0;
Serial.begin(boad);
Serial.print(boad);
SweetEpicDude1:
That's because learning about C strings doesn't mean "spell it with a small s".
char myText[] = "This is a C string. It is a char array with ASCII text ending in a NULL (ie 0) char.";
myText[ 0 ] == 'T'
myText[ 1 ] == 'h'
Waste your time with String and when you want to do something non-trivial it will be unexplainable crash time.
