String and string new data type
Dear All
What is the different between "String" and "string" data types
In the above first word letter S is upper case and nest word s is lower case
Please advice
Thanks in advance
http://www.arduino.cc/en/Reference/String
https://www.arduino.cc/en/Reference/StringObject
A String is an object you create from the String class. It has a number of class functions that you can use to manipulate the character data. A string is a data type that is constructed from a char array. C strings are always terminated with the null character ('\0'). Because C strings are not an object of a class, a "family" of string processing functions (i.e., str*() and mem*()) are available for you to use in lieu of class member methods. You can see most of the C string functions at:
http://www.tutorialspoint.com/c_standard_library/string_h.htm
Dear econjack Thanks for the reply
Please advice how does following code print after two new lines
Serial.println("\n\nString toInt():");
It has two new line command \n \n
but all are constant string
Please advice
Serial.println() prints one newline "\n\n" prints two more newlines
There are a number of special characters defined for C, and they are introduced with a slash. If you google "C escape sequences" you should be able to get a complete list of them (e.g., Beginning C for Arduino, 2nd Ed., Table 10-1).
