String blijft "0" help aub
Hoi,
Vanaf regel 75 een aantal if else ..
De String "flapDisplay" blijft echter "0" na de laatse else. (regel 99)
Iets gaat hier fout maar ik staar me blind en vind het niet.
Hulp wordt zeer op prijs gesteld.
Dank
// ******************************************** OLED Display ********************************************
#include "U8glib.h"
U8GLIB_SH1106_128X64 u8g(U8G_I2C_OPT_NO_ACK);                     // Display which does not send ACK
// ********************************************** BME280 ************************************************
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define BME_SCK 13
#define BME_MISO 12
#define BME_MOSI 11
#define BME_CS 10
#define Sealevel_HPA (1013.25)                                    // Set sealevel
Adafruit_BME280 bme; // I2C
unsigned long delayTime;
// ******************************************* FLAPS Sensor ********************************************
int AGL = 0;                                                      // Set initial heigth
int QNH = 0;                                                      // Set initial QNH
int sensorPin = A0;                                               // select the input pin for the flaps potentiometer
int sensorValue = 0;                                              // variable to store the value coming from the sensor
int tol = 5;                                                      // set tolerance flaps slider
// ****************************************** Rotary Encoder *******************************************
#define inputCLK 8                                                // Set input pin CLK
#define inputDT 9                                                 // Set input pin DT
int pinwaarde = 0;
int var = 0; //tijdelijk
int mode = 0;
int flap = 0;
int flapDisplay = 0;
int counter = 0;                                                  // Initial encoder count
float currentStateCLK;                                            // Initial CLK state
float previousStateCLK;                                           // Previous CLK state
String encdir = "";
// ****************************************** General Setup ********************************************
  int gearPin = 5;
  int buzzerPin = 6;
  // Rotary encoder setup
  pinMode (inputCLK, INPUT);                                      // Set encoder pins as inputs
  pinMode (inputDT, INPUT);
  pinMode (7, INPUT);                                             // Set input pin encoder switch
  pinMode (buzzerPin, OUTPUT);                                    // Buzzer pin
  pinMode (gearPin, INPUT);                                       // Gear down switch
  Serial.begin(9600);                                             // Start serial port
  unsigned status;
  status = bme.begin();
  mode = 0;
  // ******************************************* Read value string potmeter ****************************
  sensorValue = analogRead(sensorPin);                                                      // Read value flaps string potmeter
  if      (sensorValue > 100 - tol && sensorValue < 150 + tol)  {
    String flapDisplay = String ("1");                                                      // Flaps 1
  else if (sensorValue > 200 - tol && sensorValue < 250 + tol)  {
    String flapDisplay = String ("2");                                                      // Flaps 2
  else if (sensorValue > 250 - tol && sensorValue < 275 + tol)  {
    String flapDisplay = String ("2.5");                                                    // Flaps 2.5
  else if (sensorValue > 300 - tol && sensorValue < 350 + tol)  {
    String flapDisplay = String ("3");                                                      // Flaps 3
  else if (sensorValue > 400 - tol && sensorValue < 450 + tol)  {
    String flapDisplay = String ("4");                                                      // Flaps 4
  else if (sensorValue > 500 - tol && sensorValue < 550 + tol)  {
    String flapDisplay = String ("L1");                                                     // Flaps L1
  else if (sensorValue > 600 - tol && sensorValue < 650 + tol)  {
    String flapDisplay = String ("L2");                                                     // Flaps L2
  else {
    String flapDisplay = String ("--");                                                     // Flaps --
  Serial.println(flapDisplay);
  pinwaarde = digitalRead(7);
  if (pinwaarde == LOW) {
    setElevation();
  // Print QNH
  Serial.print("QNH = ");
  Serial.print(int(bme.readPressure() / 100.0F));
  Serial.print(" hPa ");
  QNH = (int(bme.readPressure() / 100.0F));
  // Print AGL
  AGL = (bme.readAltitude(Sealevel_HPA));
  Serial.print("AGL = ");
  Serial.print (AGL + counter);
  Serial.println(" m");
  if  ((AGL + counter < 150) && (digitalRead(5) == HIGH)) {                                 // Set Landing gear warning altitude and determine if gear is down
    digitalWrite(6, HIGH);
  else if (AGL + counter >= 150) {
    digitalWrite(6, LOW);
  // **********************************   Draw data *******************************************
  u8g.firstPage();
  do {
    draw();
  } while ( u8g.nextPage() );
void draw(void) {
  //u8g.setRot180();        // Rotate display 180 degrees
  u8g.setFont(u8g_font_profont15);
  u8g.drawStr( 85, 10, "Elev");
  u8g.setFont(u8g_font_helvR12);
  u8g.setPrintPos(85, 25);
  u8g.print(AGL + counter);
  u8g.drawStr( 85, 45, "QNH");
  u8g.setPrintPos(85, 60);
  u8g.print(QNH);
  u8g.setFont(u8g_font_6x10);
  u8g.drawStr(5, 7, "flaps");
  u8g.setFont(u8g_font_fub49n);
  u8g.setPrintPos(1, 63);
  u8g.print(flapDisplay);
// ********************************* Subroutine AGL setting ******************************************
void setElevation() {                                             // Set Elevation
  var = 0;
  while (var < 1) {
    pinwaarde = digitalRead(7);                                   // Read pinvalue ecncoder switch
      mode++;
      if (mode == 3)                                              // Long press value encoder switch for break out of loop
        break;                                                    // Return to main
    currentStateCLK = digitalRead(inputCLK); inputCLK;            // Read the current state of inputCLK
    if (currentStateCLK != previousStateCLK) {
      if (digitalRead(inputDT) != currentStateCLK) {
        counter --;
        encdir = "CCW";
        // Encoder is rotating clockwise
        counter ++;
        encdir = "CW";
      Serial.print (AGL + counter);                               // Print AGL modified
      previousStateCLK = currentStateCLK;                         // Update previousStateCLK with the current state
Dit declareert en initialiseert een nieuwe lokale variabele "flapDisplay". Als je een bestaande variabele in de parent scope wilt wijzigen mag je geen nieuwe declareren met dezelfde naam.
Probeer het volgende:
flapDisplay = "1";
Pieter
In dat geval blijft "flapDisplay" 1.
Haal ik de int helemaal weg dan krijg ik de volgende foutmeding:
'flapDisplay' was not declared in this scope
De globale variabele flapDisplay moet ook een String zijn als je er een String in wilt opslaan, en geen int.
Sorry ik kom er niet uit.
Wat zet ik waar?
Het is opgelost, iets verkeerd gedaan met de string flapDisplay
