Mine uses the actual start and end EEPROM locations as parameters for the for loop without the need for an offset from zero. This is less confusing to write and maintain
Are you saying that such a for loop does not do what you want and, if so, what proof do you have ?
I assume that you have got a call to EEPROM.begin() in the sketch that you have not posted. Or have you ?
Please post a complete sketch that illustrates whatever problem that you are having
Yes, @who_took_my_nick said in the original post he was using Esp8266 (but not not which board).
@who_took_my_nick are you aware that esp8266 has no eeprom? The data is actually written to flash memory, the same type of memory the sketch is stored. The eeprom library is provided for backwards compatibility with older types of Arduino that do have eeprom.
Writing your Strings to emulated eeprom is making life difficult, having to erase, understand the location of the start of each String, assuming maximum lengths for the Strings etc. It might be easier to store your Strings in file in flash memory. Esp has a library to emulate writing and reading files to flash memory just like an external SD card. Could this be an easier way for you?
You don't need to concatenate a line of html to send a line of html on serial.
All you need to do is fill the serial out buffer faster than it prints which in Arduino-land even 115200 baud is slow.
You don't need to add texts, just print them directly from flash in order, done.
A C++ String is a container in RAM with the text in the container accessed by the methods of the container. A pointer to String points to a container with its own text.
A C string is text chars ending with a zero whether in RAM, EEPROM, flash, SD or serial data.
A C string pointer points to data, not a container with a copy unless you code it that way.
For the most part, C strings can be treated as arrays of ASCII data, '0' + 9 == '9' == 57.
Get comfy at that level, you can process text at the char level on the fly.
