Hello!
What is wrong with my code, and when I write "Say hello" it does not respond "Hello" to the serial?
String incomingByte;
if (Serial.available() > 0)
// read the incoming byte:
incomingByte = Serial.read();
if(incomingByte.equals("Say hello"))
Serial.println("Hello");
You read one single byte from the Serial line and expect that to equal the whole string "Say Hello"? One byte from serial is only one character.
Ok, and if I want to read a word, how I know when to stop reading?
alex5678:
That's the big question. The usual answer is to surround the data you're sending with markers to let the code know where the message begins and ends. Like [Say Hello] or something.
See the Serial Input Basics thread for some good reading on this topic.
First, the String class (note the capital 'S') is wasteful of memory and can fragment it. Use C strings (note lower case 's') built from char arrays instead. As to your question, Delta_G has one suggestion, here's another:
char msg[30];
int charsRead;
charsRead = Serial.readBytesUntil('\n', msg, sizeof(msg) - 1); // Leave room for null
msg[charsRead] = '\0';
Serial.println(msg);
With this code, just type a short message into the Serial monitor input textbox and press the Enter key. The newline character ('\n') marks the end of the input stream.
econjack:
OP might have to set up serial monitor to append the newline character when he/she presses 'send'.
econjack:
char msg[30];
int charsRead;
Thank you, it worked!
