Hi.
I will explain what I'm trying to do.
I have 2 strings, one of them is called address and is static the other one is called receiver and will hold the last 5 characters received by the serial Rx of my 328P.
When they are equal a text sent through the serial port should indicate so.
#define pin2 0
#define pin3 1 //SERIAL
#define pin4 2 //SERIAL
#define pin5 3 //PWM
#define pin6 4
#define pin11 5 //PWM
#define pin12 6 //PWM
#define pin13 7
#define pin14 8
#define pin15 9 //PWM
#define pin16 10 //PWM
#define pin17 11 //PWM
#define pin18 12
#define pin19 13
#define pin23 A0 //analog
#define pin24 A1 //analog
#define pin25 A2 //analog
#define pin26 A3 //analog
#define pin27 A4 //analog
#define pin28 A5 //analog
#define TRUE 1
#define FALSE 0
char receiver[] = "00000";//goes from receiver[0] to receiver receiver[4]
char address[] = "00001";
char buffer;
int i;
void setup(){
Serial.println("Initialized");
void loop(){
if(Serial.available() > 0){
buffer = Serial.read();
receiver[i] = buffer;
i++;
if(receiver[4] != 48){//48 = number 0 character os ascii table
i = 0;
if(receiver == address){//the problem is here, even if both strings have the same value it will not execute what is in this operator.
Serial.println("they are equal!");
Serial.print("Receiver: ");
Serial.println(receiver);
Serial.print("Address: ");
Serial.println(address);
