String Comparison
So I have the Parallex RFID module hooked up to my Arduino. It came with two RFID tags with two unique ID’s. I’m trying to check the currently scanned tag’s code against a “master code”. If they match more code will execute. Im using the strcmp method without much luck. Here is my current code, any help would be appreciated.
// RFID reader for Arduino
// Wiring version by BARRAGAN <http://people.interaction-ivrea.it/h.barragan>
// Modified for Arudino by djmatic
int rPin = 8;
int gPin = 9;
int  val = 0;
int checkVal = 0;
char code[10];
char checkCode[11] = "0F03040281";
int bytesread = 0;
Serial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
pinMode(rPin, OUTPUT);
pinMode(gPin, OUTPUT);
pinMode(2,OUTPUT);   // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
digitalWrite(2, LOW);                  // Activate the RFID reader
  if(Serial.available() > 0) {          // if data available from reader
    if((val = Serial.read()) == 10) {   // check for header
      bytesread = 0;
      while(bytesread<10) {              // read 10 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
            break;                       // stop reading
          code[bytesread] = val;         // add the digit
          bytesread++;                   // ready to read next digit
      if(bytesread == 10) {        // if 10 digit read is complete
        if(strcmp(code, checkCode) == 0){  // I've checked code against code.  It worked and printed good as expected.
          Serial.println("GOOD");
        }else{
          Serial.println("BAD");
        Serial.print("TAG code is: ");   // possibly a good TAG
        Serial.println(code);            // print the TAG code
      bytesread = 0;
           delay(1000);                       // wait for a second
// extra stuff
// digitalWrite(2, HIGH);             // deactivate RFID reader
The code variable is an array of chars. To make it a string, for strcmp, it needs to be NULL terminated.
[glow]          code[bytesread] = '\0';[/glow]
THe code variable needs to be declared 1 larger to hold the terminating NULL, too.
I tried everything but that ::)
Thanks alot, I appreciate it.
