String concat / pass string parameters to functions problems
Hi All,
I implemented a gateway to receive IR and RF signals to control Philips Hue lamps
and
and convert some IR commands to RF.
I have some problem in generating the command to be sent to the server.
I need to create a message like:
on: true,
bri: 150,
hue: 65,
sat: 20
I create two functions.
  • setHue(int hueID, String command) that send the proper command to the light
  • setHue( int hueID, boolean on, int hueBri, long hueHue, long hueSat)
    to concatenate the 4 parameters (on/off, bri, hue, sat)
The first function works only if the command is very short
If I run the function setHue with a short command everything is fine,
otherways Arduino doesn't boot.
//This works
setHue(1, "{   \"on\":true}");
//This doesn't work (but compiles with no problems)
setHue(1, "{   \"on\":true,  \"hue\": 168,  \"bri\": 24975,  \"sat\": 253}");
Here is the code for the other function
boolean SetHue(int hueID, boolean on, int hueBri, long hueHue, long hueSat)
  String hueCmd="{";
  if(on==1){
    hueCmd = hueCmd + "\n \"on\":true";
    if(hueHue>0){
      hueCmd = hueCmd + ",\n \"hue\": " + String(hueHue);
     if(hueBri>0){
      hueCmd = hueCmd + ",\n \"bri\": " + String(hueBri);
    if(hueSat>0){
      hueCmd = hueCmd + ",\n \"sat\": " + String(hueSat) ;
    hueCmd = hueCmd + "}";
    hueCmd = "{\"on\":false}";
  return SetHue(hueID, hueCmd);
Here is the complete source code
~~http://pastebin.com/Zv31F6hf~~
Attached you can find the complete source code
IR_RF.ino (6.97 KB)
Wrong place for it. You can attach it to your post, using the Additional Options link.
I'm going to go out on a limb (because I'm betting it isn't very far) and guess that you are running out of memory from pissing resources away on the String class.
PaulS:
Fixed :blush:
PaulS:
Do you suggest to use a different programming approach (char or other) or to move to an Arduino Mega or Due?
Dump the string class and use arrays of char. Sprintf will be handy.
You have a lot of string literals in your code. Move them to progmem: client.print and serial.print can use the F macro:
    Serial.print(F("Light  : "));
Also, the long strings you're using in mySwitch.send should be stored in progmem.
