String conversion Error
I've made two functions. One (called Read3digits) returns a string, and the other function takes a string as argument. Previously I had these two functions in one but for the sake of readability I've split them in to two functions. Now when I try to compile I get the error
could not convert 'Read3digits' from 'String (*)()' to 'String'
Can someone tell me why my String is suddenly a String(*)() and how do I convert it to a normal String?
Do you think that it might help if you posted your sketch ?
I certainly do
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
#include <SPI.h>
#include <MFRC522.h>
#include <Wire.h>
#include <Adafruit_GFX.h>       // version 1.3.6
#include <Adafruit_SSD1306.h>   // version 1.2.9
#define RST_PIN         9
#define SS_PIN          10
MFRC522 mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance
Adafruit_SSD1306 display(128, 64, &Wire, -1, 400000);  // 400kHz I2C clock
	while (!Serial);
	SPI.begin();
	mfrc522.PCD_Init();
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  delay(100);
  display.clearDisplay();
  display.display();
	// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
	if ( ! mfrc522.PICC_IsNewCardPresent()) {
		return;
	// Select one of the cards
	if ( ! mfrc522.PICC_ReadCardSerial()) {
		return;
  IntToDisplay(Read3digits);
void IntToDisplay(String str){    //Displays the given string
  display.setCursor(0,0);
  display.setTextSize(7 );
  display.setTextColor(1);
  display.print(out);
  display.display();
  delay(200);
String Read3digits(){   //Reads 3 bytes from the NFC card and returns it as ASCII values as a string
  MFRC522::StatusCode status;
  byte byteCount;
  byte buffer[18];
  String out;
  byte i;
    byteCount = sizeof(buffer);
    status = mfrc522.MIFARE_Read(6, buffer, &byteCount);
    // Dump data
      for (byte index = 1; index < 4; index++) {
        i = index;
        out += ((char)buffer[i]);
  mfrc522.PICC_HaltA();
  return out;
I've used the Copy for Forum button. Is this the correct way to post code? And this is the code. Thanks in advance.
Yes, and it is also the easiest
You are not actually calling the Read3digits function
Try
  IntToDisplay(Read3digits());
However, there are other problems
In IntToDisplay() you have
  display.print(out);
but out is not in scope at that point because you declared it in the Read3digits() function. Either make it a global so that it is available anywhere in the sketch or return it from Read3digits() and pass it to IntToDisplay(). In fact, that function is passed a String which you named str which is never used
Indeed a simple fix. I also changed out to str. Thank you!
