String does not work with println. Documentation bug?
There is an inconsistency between actual behavior and the arduino documentation. http://arduino.cc/en/Reference/StringConstructor http://arduino.cc/en/Serial/Print
According to the documentation, a String can be initialized using a constant in the form of "some text here". However this fails to add a null terminator to the end of the String. As such this code does not work:
String settings[]={ "CURSOR_DRIVER" "BRLTTY_DRIVER" "BUFFER_SIZE_MAX" "BUFFER_COLUMNS" "BUFFER_ROWS" "DOTCOUNT"};
void setup() { Serial.begin(9600); Serial.println(settings[0]); }
void loop() { // put your main code here, to run repeatedly:
It prints: CURSOR_DRIVERBRLTTY_DRIVERBUFFER_SIZE_MAXBUFFER_COLUMNSBUFFER_ROWSDOTCOUNT (Along with no amount of garbage, if there doesn't happen to be a \0 somewhere in the next kilobyte of memory...)
While this code does work:
String settings[]={ "CURSOR_DRIVER\0" "BRLTTY_DRIVER\0" "BUFFER_SIZE_MAX\0" "BUFFER_COLUMNS\0" "BUFFER_ROWS\0" "DOTCOUNT\0"};
I must note, that this is really only a problem in documentation. The documentation for the print command clearly states that it works on any data type:
http://arduino.cc/en/Serial/Print val: the value to print - any data type
And yet in reality, it works on NULL terminated strings but not length bounded Strings....
I am on Arch linux.
$pacman -Q arduino arduino 1:1.0-2
$ uname -a Linux timothy 3.2.5-1-ARCH #1 SMP PREEMPT Tue Feb 7 08:46:10 UTC 2012 i686 Intel(R) Core(TM)2 Duo CPU L7500 @ 1.60GHz GenuineIntel GNU/Linux
Timothy Hobbs
Not sure what you're trying to do, but I think your initialisation list is missing some commas.
In C/C++, you can write
char* myString = "This"
" is a "
" long string";
And the compiler will happily concatenate it into "This is a long string".
What happens if you try this:
  Serial.println(settings[1]);
with your second example?
Ah, aha, you're right! Thank you. I'm surprised that even compiled. Sorry for the false report. I didn't even see the error in my code.
I have to admit, I assumed the presence of the missing commas on my first reading.
timthelion: Ah, aha, you're right! Thank you. I'm surprised that even compiled. Sorry for the false report. I didn't even see the error in my code.
C concatenates multiple strings into a single string. So:
"string1""string2"
"string1" "string2"
and
"string1"
"string2"
are all the same as:
"string1string2"
--- bill
Bill, see reply #1
