I have the following function piece of cake in my ESP8266 based NodeMCU:
snprintf ( temp, 800,
NodeMCU DHT11 Sensor \and Relay Board\
body { background-color: #cccccc; font-family: Arial, Helvetica, Sans-Serif; Color: #000088; }\
li { margin: 10px 0;}\
Hello from NodeMCU!
Temperature: %02d ℃
Humidity: %2d %
Turn Relay 1 On\/Off\
- Turn Relay 2 On\/Off
Uptime: %02d:%02d:%02d
t, h, !digitalRead(5), !digitalRead(4), hr, min % 60, sec % 60
if I try to use ternary operator like shown below , it freezes and doesn't work
Hello from NodeMCU!
Temperature: %02d ℃
Humidity: %2d %
Turn Relay 1 %s\
- Turn Relay 2 %s
t,
h,
!digitalRead(5),
!digitalRead(5),
(digitalRead(5) ? "Off" : "On"),
(digitalRead(4) ? "Off" : "On")
Please read Nick Gammon's post at the top of the Forum on the proper way to post code using code tags.
t,
h,
!digitalRead(5),
!digitalRead(5),
You have ordered the prameters badly, you are reading a wrong port
t,
h,
!digitalRead(5), (digitalRead(5) ? "Off" : "On"),
!digitalRead(4), (digitalRead(4) ? "Off" : "On")
Thank you so much Whandall, some times I am blind to spot tiny bits . I was seeing &5 as %d.
