Hey, I'm trying to get the Arduino to take in a 6-digit numerical string from a processing sketch. Since the Arduino reads serial one character at a time, what would be the best way to assemble the 6 characters into a single integer variable?
Thanks
Thanks
The easiest to understand is to wait until all 6 characters have arrived, then read them, and store them in an array.
int index;
char inData[8]; // Or however many...
if(Serial.available() >= 6)
index = 0;
for(byte i=0; i<6; i++)
inData[index] = Serial.read();
index++;
inData[index] = '\0'; // Keep string NULL terminated
// Use inData for whatever; use atoi(inData) to convert to int
and then use atoi() to get them into an integer.
Does it really look like this,int myArray[7] = {0, 1, 2, 3, 4, 5}; ?
Or is it more like thisint myArray[7] = {'0', '1', '2', '3', '4', '5'}; ?
If the former, then simply multiply each array element by the appropriate power of ten, and sum the values.
Watch out for values over 32767.
Sorry about deleting the post, I thought I had it for a second. The array is not being manually defined, it's being defined one digit at a time from the loop shown in the second post of this thread.
Here's an example of what I'm having a problem with:
char myArray[7] = {'0', '1', '2', '3', '4', '5'};
void setup () {
void loop () {
Serial.println(atoi(myArray));
This outputs "12345" which is fine, that will work perfectly for what I need. The problem is that the highest end of the range of the number is over 100000, so say the number I'm trying to read is "123456", if I try:
char myArray[7] = {'1', '2', '3', '4', '5', '6'};
void setup () {
void loop () {
In this example, rather than getting "123456", I'm getting "-7616". I can't for the life of me understand where this value is coming from unless "atoi()" has some kind of limit.
an "int" has a range -32768 to +32767.
That makes sense that that would have been over the limit for int, so I tried using "long" instead of "int". Even though I'm well within the range for a "long" variable, I'm still getting the "-7616", any ideas?
void setup () {
void loop () {
long num = atoi(myArray);
Serial.println(num);
EDIT: I was starting to fry my brain trying to figure this out, then it hit me, if "atoi()" stands for "ASCII to Int", what would happen if I changed the "i" to an "l" for long, low and behold it worked.
Be very careful - your array is only working here because the compiler is filling unused elements with zero.
In a running system, this advantage may disappear, as string lengths change.
Btw. Just to be sure, I would explicitly terminate the string:
char myArray[7] = {'1', '2', '3', '4', '5', '6', '\0'};
or
char myArray[] = "123456";
Sometimes the compiler does the right thing implicitly, but I always prefer to see explicitly what's going on.
Well, like I said, I wasn't defining the array manually, the array is being created by reading serial one character at a time. I only posted the "{'1', '2', '3'}" example to show what the array contains, not how it's created. The "atol()" function seems to be working well for what I need.
So that you don't waste people's time, it is best for everyone if you post the code that you're actually using.
Passing unterminated strings to library routines is a common noob bug.
