Hi all,
I'm working on serial communication with UNO and SIM900
Here is my full code. Sorry if too long or not practical.
* A sketch for Arduino UNO board
* - Get cell data from tower
* - Parsing and tokenizing
* - Send data to server
#include <SoftwareSerial.h>
const unsigned long Period = 20000ul; // every 20 seconds
int bGetCellData = 1; // control bit to get data or send data
static char IMEI[15];
SoftwareSerial ConnectSerial(7, 8); // instantiate serial object, connecting the the GSM Serial hardware
ConnectSerial.begin(19200); // GPRS shield baud rate
ConnectSerial.println("AT+CENG=3"); // activate engineering mode
delay(100);
ConnectSerial.println("AT+GSN");
delay(100);
static unsigned long tempo = millis();
static char celldata[256];
static char jsonString[600];
static int i = 0;
if (bGetCellData == 1) {
if (millis() - tempo > Period) {
findingIMEI(celldata, IMEI);
ConnectSerial.println("AT+CENG?"); // reading information
i = 0;
tempo = millis();
memset(celldata,0,sizeof(celldata));
memset(jsonString,0,sizeof(jsonString));
while(ConnectSerial.available()) {
celldata[i++] = ConnectSerial.read();
if ((i > 0) && strstr(celldata,"+CENG:0") && strstr(celldata,"OK")) {
getLocInfo(celldata, jsonString, IMEI);
i = 0;
bGetCellData = 0;
else {
Serial.println(jsonString);
tempo = millis();
bGetCellData = 1;
* function to process receiving data
* including parsing and tokenizing
void getLocInfo(char * celldata, char * returnString, char * imei) {
char lines[7][60];
char temp[128];
int line = 0;
int c = 0;
int i = 0;
long mcc;
long mnc;
long lac;
long cid;
long rxl;
memset(lines,0,sizeof(lines));
char * str = strstr(celldata,"+CENG:0");
while (*str != '\0') {
if (line > 6)
if (*str == '\n') {
line++;
c = 0;
else {
lines[line][c] = *str;
c++;
str++;
sprintf(temp, "{\"celldata\":{\"cells\":[");
strcat(returnString, temp);
while (i < 7) {
tokenize(lines[i], &mcc, &mnc, &lac, &cid, &rxl);
sprintf(temp, "{\"cell\":\"%d\",\"mcc\":\"%ld\",\"mnc\":\"%ld\",\"lac\":\"%ld\",\"cid\":\"%ld\",\"rxl\":\"%ld\"}", i, mcc, mnc, lac, cid, rxl);
if (i < 6){
strcat(returnString, ",");
i++;
sprintf(temp, "]},\"ID\":\"%s\"}", imei);
* function to tokenize from line of data separated by comma
void tokenize(char * line, long * mcc, long * mnc, long * lac, long * cid, long * rxl) {
char * token = NULL;
char storeCENG[10];
char mcc_char[6];
char mnc_char[6];
char lac_char[6];
char cid_char[6];
char bsic_char[6];
char rxl_char[6];
* use strtok to separate each parameter
* use strtol to convert from string to long
strcpy(storeCENG, strtok(line,","));
*mcc = strtol(strcpy(mcc_char, strtok(NULL,",")),NULL,10);
*mnc = strtol(strcpy(mnc_char, strtok(NULL,",")),NULL,10);
*lac = strtol(strcpy(lac_char, strtok(NULL,",")),NULL,16);
*cid = strtol(strcpy(cid_char, strtok(NULL,",")),NULL,16);
strcpy(bsic_char, strtok(NULL,","));
*rxl = strtol(strcpy(rxl_char, strtok(NULL,",")),NULL,10);
* function to get IMEI number as a ID number
void findingIMEI(char * input, char * returnIMEI) {
int j = 0;
char * ptr = strstr(input, "AT+GSN\r");
while (*ptr != '\0') {
if (*ptr == '\n' || *ptr == '\r' || *ptr == 'A' || *ptr == 'T' || *ptr == '+' || *ptr == 'G' || *ptr == 'S' || *ptr == 'N') {
ptr++;
else {
returnIMEI[j++] = *ptr;
if (j == 15) {
ptr++;
I get the result on monitor as shown below.
{"celldata":{"cells":[{"cell":"0","mcc":"520","mnc":"18","lac":"14011","cid":"7879","rxl":"40"},{"cell":"1","mcc":"520","mnc":"18","lac":"14011","cid":"4688","rxl":"18"},{"cell":"2","mcc":"520","mnc":"18","lac":"14011","cid":"7877","rxl":"17"},{"cell":"3","mcc":"520","mnc":"18","lac":"14011","cid":"7878","rxl":"13"},{"cell":"4","mcc":"0","mnc":"0","lac":"0","cid":"0","rxl":"21"},{"cell":"5","mcc":"0","mnc":"0","lac":"0","cid":"0","rxl":"21"},{"cell":"6","mcc":"0","mnc":"0","lac":"0","cid":"0","rxl":"20"}]},"ID":"013950007xxxxxx220000,16,21
+CENG:6,000,00,0000,000
At "ID": "013950007xxxxxx"} <- This should end here with bracket.
My question is why the place that should be a close bracket } has more string instead? How can I fix this?
Thanks
