void atsendbasic(String command){
Serial2.write(command);
while (!Serial2.available()) continue;
while (Serial2.available()) {
char feedback = Serial2.read();
Serial.print(feedback);
I plan to use the function in my main code like so atsendbasic("AT+command/r/n") and I will then read the modem's response and post it to the serial monitor. This approach does not work though. The line where I attempt Serial2.write(command); is giving errors.
Getting error:
exit status 1
no matching function for call to 'HardwareSerial::write(String&)'
I've seen a stack overflow post that appears to solve the problem but it doesn't work for me. Not sure why though. Using this approach my code would look like:
void atsendbasic(const String& command){
Getting about the same error:
exit status 1
no matching function for call to 'HardwareSerial::write(const String&)'
Serial.write() writes the value of the bytes or bytes sent to it, but a String is not a series of bytes in that sense, rather it is an object created using the String library
As the error message says, Serial.write() cannot write a String, however, Serial.print() can
I read @UKHeliBob suggestion and didn't realize it was indicating this but thanks to @killzone_kid for pointing out this .c_str() I don't know exactly how I would've applied this but I am reading the documentation.
Serial2.write(command.c_str());
Serial2.flush(); // Wait until it is all sent
Serial.print(Serial2.read());
I see now how to use the .c_str() functionality. I may add the Serial2.flush command as well. But I am curious as to why the command Serial2.write("AT+CPIN?\r\n");works but this which looks to me to be the same thing does not?
Because "AT+CPIN?\r\n" is a c-string literal and .write() has an overload for that. On the other hand your 'command' variable is an instance of the String class and .write() DOES NOT have an overload for that.
Of course there is no real need to create a String which will slow things down and use more memory than really needed - or worse could silently fail if you are low in SRAM
void atSendReallyBasic(const char* command)
while (!Serial2.available()) yield();
while (Serial2.available()) Serial.write(Serial2.read());
It is also likely that you’ll empty Serial2 buffer faster than it’s getting filled and thus won’t read the full answer with such a code, esp if the answer is long
This is very interesting code. I am doing something similar but instead of using sms I am doing mqtt protocol so the sending or in my case publishing of messages is quite different. But we do have two portions of our main codes that are similar: checking that the modem responds to "AT" and looking for error messages after general AT commands.
As I mentioned one of the first things I do is send "AT" and if there is no response I assume the modem is off and execute a hardware modem boot procedure. The code is still under development, but I am doing some testing today.
void modemverification () {
Serial2.write("AT\r\n");
unsigned long timeout1 = millis();
if (Serial2.available() > 0 && millis() - timeout1 <= 60000) {
char verificationinfo = Serial2.read();
Serial.println("VERIFIED");
verified = 1;
else {
verified =0;
For some of the important AT commands (est PDP context and make SSL connections) I am scanning for errors with this block.
void atsenderrorcheck(String commandcheck){
Serial2.print(commandcheck);
while (Serial2.available() > 0){
static char message[MAX_MESSAGE_LENGTH];
static unsigned int message_pos = 0;
char inByte = Serial2.read();
if ( inByte != '\n' && (message_pos < MAX_MESSAGE_LENGTH - 1) )
message[message_pos] = inByte;
message_pos++;
message[message_pos] = '\0';
Serial.println(message);
message_pos = 0;
if (strcmp(message,"ERROR\r")==0) {
Serial.println("ERROR DETECTED");
errorfunction = 1;
else {
Serial.println("NO ERROR DETECTED");
errorfunction =0;
