String issue
Hello,
I’m trying read a SMS from a Ericsson t68i with Arduino and them, do somethings.
So, the t68i just uses PDU format, and when I try to read the message, it comes incomplete.
this is the code i’m using:
#include <NewSoftSerial.h>
#include <avr/pgmspace.h>
NewSoftSerial Uart(10, 11);
int buttonState = 0;
int botao = 12;
int rele = 13;
String send_command(String at_cmd, int dly){
  String msg;
  char incomingByte;
  Uart.println(at_cmd);
  delay(dly);
  while (Uart.available() > 0)
    incomingByte = (Uart.read());
    msg = msg + char(incomingByte);
  return msg;
  Uart.begin(9600);
//Coloca o pino 13 em Output onde será ligado o relé
  pinMode(rele, OUTPUT);
  pinMode(botao, INPUT);
  String at_response;
  String at_response2;
  String at_response3;
  String at_response4;
  at_response = send_command("AT+CPMS=\"ME\"",1000);
  if (at_response.substring(at_response.length()-4) == ("OK\r\n")) {
    Serial.println(at_response);
  at_response2 = send_command("AT+CMGR=1",1000);
 Serial.print(at_response2);
The answer I get:
+CPMS=“ME”
+CPMS: 1,70,0,30,1,70
OK
+CMGR=1
+CMGR: 1,24
0791551118312800240B811079186914F500001
So, the last line is the message in PDU format (at_response2). It should be like this:
0791551118312800240B811079186914F500001101313204812905CCF4392C07
How can I solve it?
Thank you so much!
Returning automatic variables is rarely a good idea.
AWOL: Returning automatic variables is rarely a good idea.
why?
  return msg;
Why delay before returning?
why?
The variable you are returning goes out of scope (ceases to exist) when the function ends. You returned a pointer to the memory space that the variable was using, that may get overwritten at any time.
You should pass the function a reference to the place where you want it to write data to.
void send_command(String at_cmd, int dly, String &reply)
Then, get rid of msg, replace all references to msg with reply, and remove the return statement.
PaulS,
I got this code here: http://arduino.cc/playground/Main/SonyEricsson
So, with some work i did it work with my cell phone. So somethings i didn't undertand yet.
Thats why I don't know about this delay before returning and I didn't undertand so much, how may I do in this part of code that you did.
it's to be like this?
void send_command(String at_cmd, int dly, String &reply){
 // String msg;
  char incomingByte;
  delay(dly);
    reply = reply + char(incomingByte);
  return reply;
Works, I suppose, but
    reply += incomingByte;
is all that is required, and certainly looks cleaner.
  return reply;
What part of "and remove the return statement" didn't you understand?
Sorry about the return, i read again what you said and I corrected it before your answer.
It’s returning an error to compile:
projeto_lab.cpp: In function ‘void setup()’:
projeto_lab:13: error: too few arguments to function ‘void send_command(String, int, String)’
projeto_lab:49: error: at this point in file
projeto_lab:59: error: at this point in file
projeto_lab:67: error: at this point in file
The full code now is:
// String msg;
char incomingByte;
delay(dly);
// reply = reply + char(incomingByte);
// delay(1000);
//return reply;
Uart.begin(9600);
String at_response;
at_response = send_command(“AT+CPMS=“ME””,1000);
if (at_response.substring(at_response.length()-4) == (“OK\r\n”)) {
at_response2 = send_command(“AT+CMGR=1”,1000);
The send_command function now requires three arguments, and does not return a value.
send_command("AT+CPMS=\"ME\"",1000, at_response);
huum, OK...now i undertood. But, this comparison is not working anymore (the answer is always NOT OK):
    Serial.println("OK");
  else {
    Serial.println("NOT OK");
There is a debug to do with this code now?
thank you man!!
Add
Serial.print("at_response: '");
Serial.print(at_response);
Serial.println("]");
after:
Show us the output.
the outpu is just:
at_response: ']
I tried the old code to make sure that the cell phone is ok, and it’s ok!
The ' should have been [.
If you copy those three lines into the send_command function, and change at_response to reply, what do you see?
PaulS: Serial.print("at_response: '");
i didn't undertand this.
PaulS, we can talk in another place (email or MSN) if you can, and after we write here the solution.
You can PM me.
I meant that
should have been
Serial.print("at_response: [");
Now it's working the debug.
But it's with the same result of the old code:
[ +CPMS="ME"
OK ] [ +CMGR=1
+CMGR: 1,,24 0791551118312800240B811079186914F500001]
But it’s with the same result of the old code:
Changing the way that the collected data is made known to the caller will not change the data.
The problem is here:
This expects all the data to have arrived by the time that the function is called. There is no guarantee that this will happen.
There is some end-of-message marker that signifies that the complete message has been received. You need to wait, in the send_command function, until that end character is received.
This is not working yet. I still have this from the phone:
+CPMS="ME"
OK
+CMGR=1
+CMGR: 1,,24
instead of:
+CPMS="ME"
OK
+CMGR=1
+CMGR: 1,,24
OK, we can see the output, but what does the code look like?
The code now is:
 // String msg;
  char incomingByte;
  delay(dly);
  Uart.begin(4800);
  String at_response;
  send_command("AT+CMGR=1", 1000, at_response2);
Serial.println(at_response2);
void loop() {}
The output is:
+CPMS=“ME”
OK
+CMGR=1
+CMGR: 1,24
The last line is the SMS message I need to read and compare. So this is incomplete.
It had to be:
thanks!
What do these numbers mean?
+CMGR: 1,,24
And these?
