system
August 19, 2014, 4:19pm
1
I am not getting the String length using the following code.
What am I missing?
Any constructive help will be appreciated.
String txtMsg = "TEST STRING "; // a string for incoming text
int lastStringLength = txtMsg.length(); // previous length of the String
if(lastStringLength)
lcd.setCursor(0,1);
lcd.print(lastStringLength);
Serial.println(lastStringLength);
Serial.println (" Empty string ");
system
August 19, 2014, 4:40pm
2
What am I missing?
setup(), loop(), and proof.
Constructive help:
Ditch String.
Use string.h and strlen().
More constructive help:
Provide a compilable, runnable example.
This code:
void setup(void)
while(!Serial);
delay(2000);
Serial.print("String length is ");
void loop(void)
prints
String length is 12
You're doing something wrong which you haven't shown us.
Pete
system
August 19, 2014, 4:52pm
5
So would you posting complete code, so we can reproduce the problem, or proving some proof that the String length is 0.
String crap = "This is not a short String";
Serial.print("String: {");
Serial.print(crap);
Serial.println("]");
Serial.print("length: " );
Serial.println(crap.length());
String: {This is not a short String]
length: 26
Is your length() method in the global area? It might need to be in an actual code section.
system
August 19, 2014, 5:03pm
7
PaulS:
What am I missing?
What he said.
+1.
Great generic answer here
system
August 19, 2014, 6:17pm
8
KeithRB:
Constructive help:
Ditch String.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
String txtMsg = "TEST String";
void setup ()
Serial.begin (115200);
lcd.begin(16,2);
lcd.backlight();
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(txtMsg);
Serial.println ("Empty string");
lcd.print ("Empty string");
void loop ()
7714 bytes.
#include <Wire.h>
char* txtMsg = "TEXT string";
int lastStringLength = strlen (txtMsg);
void setup ()
lcd.begin(16,2);
lcd.backlight();
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(txtMsg);
void loop ()
6118 bytes
Ditch String.
Constructive advice { nods assertively }
Vaclav:
What am I missing?
Turning that into a sketch ...
void setup ()
void loop () { }
I get the output:
12
So it doesn't "always" return 0.
Also, since you are assigning when you create the variable lastStringLength it will not be the "previous" length of the string, it will be the first length.
system
August 20, 2014, 3:49am
11
Thanks everybody.
I have something wrong elsewhere in MY code.
system
August 20, 2014, 6:50am
12
Vaclav:
Who'd've guessed?
That's five minutes of my life I'm not getting back.
