I am having terrible trouble finding how to do something that seems rteally simple..
I am using the serial monitor to send a command to the Arduino to set the values of an RGB led. The commands are in the form of:
r255 g127 b23
I then get the program to split the above entered text into the 3 components using the strtok command :-
void splitString(char* data) {
Serial.print("Data entered: ");
Serial.println(data);
char* parameter;
parameter = strtok (data, " ,");
while (parameter != NULL) {
setLED(parameter);
parameter = strtok (NULL, " ,");
which then calls the setLED function
I then find out if the first character of the split string is 'r', 'g', or 'b' using..
if (strncmp(data, "r", 1) == 0) { ...etc
Which is all very well.
However, the next bit I am stumpted.
Obviously if my text string entered into the serial monitor was 'r255 g127 b23' then the value of data in the setLED function will be 'r255'. I have checked the first character is valid by comparing it with r, g, or b. But now I want to take the last 1, 2 or 3 characters of the data variable, check it is valid and then turn it into a integer.
But how do I strip out the last 1, 2, or 3 characters after the 'r' ?
In other languages you might use the Right function as in Right(string,length). But how do I do this in C please?
