I'm writing a program to get the list of values of a SD card file into usable values but the string value will not convert to a int variable. The SD card file is taken from a app I built. The string that is taken from the SD card file is laid out as the following example.
List of values from app: {000.00, 123.45, 098.70, 656.00}
SD card file is laid out as: 000.00123.45098.70656.00
I'm able to put the string into char and get the individual values in the list to its own string, but when I go to set that string it does not work. Example follows:
String: 000.00
Serial Print String to int:
The part of the code where I'm attempting to the string to int is under void draw().
#include <Wire.h>
#include "rgb_lcd.h"
#include <SPI.h>
#include <SD.h>
#include <Stepper.h>
const int stepsPerRevolution = 1000;
String Yval = "";
int view = 0;
char FileChar[] = {"oof"};
char FileChar2[] = {"oof"};
int i = 0;
String Xval = "";
const int chipSelect = 4;
rgb_lcd lcd;
const int colorR = 0;
const int colorG = 0;
const int colorB = 0;
int TouchSec = 0;
int Version = 1.0;
char* Main[]= {"Print", "Information", "Options"};
int delayTime = 100;
String Select = "SELECT";
char Ymap[] = {"fun"};
char Xmap[] = {"fun"};
int X1 = 10;
int Y1 = 20;
int X2 = 10;
int Y2 = 20;
int TransX = 0;
int TransY = 0;
int Line = 0;
int slope = 0;
int Rise = 0;
int Run = 0;
int Rest = 0;
int Draw = 180;
int numX = 0;
int placeX = 0;
String CurentX = "";
int numY = 0;
int placeY = 0;
String CurentY = "";
Stepper myStepper(stepsPerRevolution, 14,15,16,17);
int val = 0;
myStepper.setSpeed(150);
int view = 1;
lcd.begin(16, 2);
lcd.setRGB(colorR, colorG, colorB);
clearScreen();
lcd.setRGB(200 , 255, 200);
if (digitalRead(8) == 1){
TouchSec++;
Print();
}else{
TouchSec = 0;
if (view == 1)
clearScreen();
void clearScreen() {
Select = String(Main[TouchSec]);
lcd.setCursor(0, 0);
lcd.print("CNC PLOTTER V1.0");
if (TouchSec == 0){
lcd.setCursor(0, 1);
lcd.print(" <" + Select + "> ");
if (TouchSec == 1){
if (TouchSec == 2){
void Print() {
myStepper.step(-60);
lcd.clear();
lcd.print("Initializing ");
lcd.print("SD Card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
lcd.clear();
lcd.setRGB(255 , 5, 5);
lcd.print("Card failed");
lcd.print("or is not present");
// don't do anything more:
while(1);
lcd.clear();
lcd.print("Card Initialized.");
myStepper.step(120);
// re-open the file for reading:
File myFile = SD.open("X.TXT");
if (myFile) {
// read from the file until there's nothing else in it:
while (myFile.available()) {
char FileChar = myFile.read();
Xval = Xval + String(FileChar);
Serial.println("XmapCheck: " + String(Xmap));
myFile.close();
File myFile = SD.open("Yval.TXT");
// if the file is available, write to it:
if (myFile) {
char FileChar2 = myFile.read();
Yval = Yval + String(FileChar2);
myFile.close();
lcd.clear();
lcd.print("Complete");
lcd.setRGB(5 , 255, 5);
Yval.toCharArray(Ymap, (Yval.length() + 1));
lcd.clear();
lcd.print("done");
wouldYouPrint();
// if the file isn't open, pop up an error:
else {
lcd.clear();
lcd.print("Error Opening");
lcd.print("File(s)");
void Info() {
void Settings() {
void wouldYouPrint() {
Line = 0;
numX = 0;
Serial.println("Ymap: " + String(Ymap));
draw();
void draw(){
Xval.toCharArray(Xmap, (Xval.length() + 1));
//get X1
numX = Line;
placeX = numX * 6;
CurentX = "";
CurentX = String(CurentX + String(Xmap[placeX]));
CurentX = String(CurentX + String(Xmap[(placeX + 1)]));
CurentX = String(CurentX + String(Xmap[(placeX + 2)]));
CurentX = String(CurentX + String(Xmap[(placeX + 3)]));
CurentX = String(CurentX + String(Xmap[(placeX + 4)]));
CurentX = String(CurentX + String(Xmap[(placeX + 5)]));
X1 = (CurentX.toInt());
Serial.println("X1: " + X1);
//get Y1
numY = Line;
placeY = numY * 6;
CurentY = "";
CurentY = String(CurentY + String(Ymap[placeY]));
CurentY = String(CurentY + String(Ymap[(placeY + 1)]));
CurentY = String(CurentY + String(Ymap[(placeY + 2)]));
CurentY = String(CurentY + String(Ymap[(placeY + 3)]));
CurentY = String(CurentY + String(Ymap[(placeY + 4)]));
CurentY = String(CurentY + String(Ymap[(placeY + 5)]));
Y1 = (CurentY.toInt());
Serial.println("Y1: " + Y1);
//get X2
numX = (Line + 1);
placeX = numX * 6;
CurentX = "";
X2 = (CurentX.toInt());
Serial.println("X2: " + X2);
//get Y2
numY = (Line + 1);
placeY = numY * 6;
CurentY = "";
X2 = (CurentY.toInt());
Serial.println("Y2: " + Y2);
//get slope
slope = ((Y2 - Y1) / (X2 - X1));
Serial.println(slope);
TransX = X1;
TransX = X1;
lcd.print(String("Start: [X:" + X1));
lcd.print(String("End: [X:" + X1));
void Translate(){
if (!(X1 == X2)){
if (X1 > X2){
TransX++;
}else{
TransX--;
TransY = TransY + slope;
Translate();
}else{
Line++;
draw();
