Hi all,
I have been using Arduinos for quite a while and love them. I have pump controllers, temp monitors and a camera mount all controlled by them. that said, I am NOT a C programmer, VB/VBS/Powershell and a bit of PHP is about it, so most of the code is fairly simple stuff.
However, having done a simple temp monitor to monitor the air and lake water temp, i thought i would replace my old weather station with an Arduino. Its been a fun thing to do and its grown that i now use an EtherMega.
Ok, to the problem. I have been monitoring the Arduino using the serial monitor, but there are things that run at midnight that i dont want to leave my laptop on over night so i can scroll back in the morning. To resolve this, as i already have code in the project that writes data to the SD card, i thought i would create a function that i can pass a String to and have it write that string to the serial monitor if available and also to a text file on the SD card. That works, but that is also when odd stuff would happen. I would see the Arduino stop responding to web requests and also see odd data appear on the serial monitor.
I have read lots of comments about String being bad, but I am not sure what or how to use something else to do what i need.
Below is the function. Is there a better way to do this? i call it with lines like this.
logEvent("Current Temp: "+String(Celcius1)+" C");
In the function below you will see that the write to the SD card file is currently commented out. This is me trying to workout where the issue is. So far without the write to the file, it seems to be stable again.
// Function to to systemlog
void logEvent(String eventText) {
char dt[16];
char tm[16];
if (Serial) {
Serial.println(eventText);
DateTime now = rtc.now();
sprintf(dt, "%02d/%02d/%02d", now.year(),now.month(),now.day());
sprintf(tm, "%02d:%02d:%02d", now.hour(),now.minute(),now.second());
String timeString = String(dt) + " " + String(tm) + " -- ";
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open(logFileName, FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(timeString + eventText);
dataFile.close();
// if the file isn't open, pop up an error:
else {
Serial.print("logEvent: error opening file ");
Serial.println(logFileName);
// timeString="";
eventText = "";
The function is called from all over the place, in the setup, in the main loop and also inside other functions. I have been careful to make sure that i dont call it while i currently have a file open.
Can anyone shed any light on a, why is this function causing the issue, b, what should i do instead of using String?
Thanks very much
Ian...
