I hitting a bit of a snag in my code that I believe should be pretty straight forward, but haven't been able to iron it out. My overall objective is to take the analog readout of a string potentiometer and display it on an LCD screen with the capability of 'zeroing out' or 'touching off' the value by pressing a button and have that displayed as a separate line displaying the distance traveled by the string potentiometer since the button was clicked. i.e. If the string pot traveled 2" and the button is pressed and then the string pot travels another 2" the readout will display 'Overall Travel:4" Touch Off Value: 2" '
Currently all of the issue comes from the code for pressing the button. I am not able to zero out the value when the button is pressed. I have checked wiring and can get values from the 'Touch off' line though. I am sure it is something fundamental that I am overlooking in my code, so I have attached the code in hope that I could be pointed in the right direction. Thanks!
String Pot Readout
Takes in analog inputs on pin0 and takes results to the serial monitor.
Attach the center pin of the potentiometer to pin A0, and the outside pins to +5V and to ground.
//Constants
const int buttonPin = 9;
const int ledPin = 3;
//Variables
int buttonState = 0;
int flag=0;
#include <LiquidCrystal.h> // LCD library
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int potPin = A0; //Potentiometer input pin
int potValue1 = 0;
int currentValue = 0; // global variables are retained on each iteration of loop()
int previousValue = 0;
int analogPin=0;
int potValue2 = 0; // final display variable
int potValue3 = 0;
int offset = 0;
//Input or output?
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP);
lcd.begin(16, 2); // lcd rows and columns
lcd.print("Travel"); // title of sorts
// read then divide the input(max 1020 in this case) by 25.4
potValue1 = analogRead(potPin);
float inches = (potValue1/26.4);
// put value into inches
lcd.setCursor(7, 0);
//display final percentage
lcd.print(inches,3);
//print the percent symbol at the end
lcd.print("In");
//wait 0.1 seconds
delay(100);
//Read button state (pressed or not pressed?)
float potValue2 = currentValue;
buttonState = digitalRead(buttonPin);
currentValue = analogRead(analogPin); // get a new reading
//If button pressed..
if(digitalRead(buttonPin)== HIGH)
buttonState==1;
{potValue3= potValue2 - potValue1;
offset= potValue3/26.4;
digitalRead(potValue1);
lcd.setCursor(0, 1);
lcd.print("Touch off"); // title of sorts
lcd.print(offset, 3);
//if touch off is pressed start value at 0
if(digitalRead(buttonPin)== LOW)
buttonState==0;
digitalWrite(buttonPin, LOW);
//wipe the extra characters
lcd.print(" ");
delay(1);
Was that block of code supposed to be part of the 'if' statement? It is unusual to start a new block for no reason.
// read then divide the input (max 1020 in this case) by 25.4
float inches = (potValue1 / 26.4);
Note: 26.4 is not 25.4. The string pot reads directly in mm?
You should get rid of delays and only read inputs once at the top of loop(). The rest of the code should not need to re-read the inputs.
String Pot Readout
//Constants
const byte ButtonPin = 9;
const byte LEDPin = 3;
//Variables
boolean ButtonAlreadyPressed = false;
int PreviousPotValue = 0;
int TouchOffPoint = 0;
const byte potPin = A0; //Potentiometer input pin
//Input or output?
pinMode(LEDPin, OUTPUT);
pinMode(ButtonPin, INPUT_PULLUP);
int currentPotValue = analogRead(potPin);
boolean buttonPressed = digitalRead(ButtonPin) == LOW; // Active LOW
// Display only when changed, to limit flicker
if (currentPotValue != PreviousPotValue)
PreviousPotValue = currentPotValue;
// Display current value in inches
lcd.print(currentPotValue / 26.4, 3);
lcd.print(" In ");
//If button just pressed..
if (buttonPressed && !ButtonAlreadyPressed)
TouchOffPoint = currentPotValue;
// Display Touch off value in inches
lcd.print("Touch off "); // title of sorts
lcd.print(TouchOffPoint / 26.4, 3);
lcd.print(" "); // Cover any old characters
ButtonAlreadyPressed = buttonPressed;
