For what? I asked what happened if you tried my suggestion. So: did it give the expected output? Or what? Did you understand how strtok() works?
It changes the input "string," so the input "string" must be in an array, not a string literal or other constant "string." (A lot of people don't like to use strtok() because of that. As far as I'm concerned: Chacun à son goût!)
in fact i need ...
You use strtok() the same way: first call it with the name of the array, and use NULL as the first parameter for subsequent calls. The delimiters argument doesn't have to be the same every time.
In your program, you would read stuff into a char array.
For purposes of testing strtok, I'll just set it up
a "string" in an initialized array.
char arr[30] = {
"!ANG:-11.35,-8.51,14.78"
char str[30];
float roll, pitch, yaw;
int errors = 0;
strcpy(str, arr);
// First is throwaway unless you want to do strcmp with "!ANG" or some such thing
char *chpt = strtok(str, ":");
if (chpt == NULL) {
Serial.println("First strok returns NULL");
++errors;
if (errors == 0) {
chpt = strtok(NULL, ",");
if (chpt == NULL) {
Serial.println("Second strok returns NULL");
++errors;
else {
roll = atof(chpt);
if (errors == 0) {
if (chpt == NULL) {
Serial.println("Third strok returns NULL");
++errors;
else {
pitch = atof(chpt);
if (errors == 0) {
chpt = strtok(NULL, ",\r\n");
if (chpt == NULL) {
Serial.println("Fourth strok returns NULL");
++errors;
// This is an input error: do something to handle it.
yaw = atof(chpt);
if (errors == 0) {
Serial.print("(");
Serial.print(roll);
Serial.print(", ");
Serial.print(pitch);
Serial.print(", ");
Serial.print(yaw);
Serial.println(")");
delay(10000);
Output:
(-11.35, -8.51, 14.78)
Regards,
Dave
Footnote:
I used strtok(). You can use strtok()_r if you want to. (Since there are no threads or other re-entrance considerations in Arduino-land, I didn't bother making it thread-safe, but thread-safety awareness is not a bad habit to get into. Maybe I should think about it some more...)
