String (str.c_str()) returns (null) instead of blank, this poses a problem when I use http request because the result is GET / (null) HTTP / 1.1 instead of GET / HTTP / 1.1. even if I display it on a lcd, I have the same thing as a result: GET / (null) HTTP / 1.1
Also, if I use sprintf(buf, "%s, ""), result is (null) instead of a blank character
it's possible to replace (null) by a blank character?
what do you mean by String (str.c_str())why would you create a new String when you already have str ??
why do you think [color=blue]""[/color] should be a blank? it denotes an empty string, one with 1 byte which is the NULL character.
try this code:
const char* s = "";
char buffer[10];
String fooString = "";
Serial.println(strlen(s)); // will show '0'
sprintf(buffer, "%s", s);
Serial.print(F("Buffer is: ["));
Serial.print(buffer);
Serial.println(F("]")); // will show 'Buffer is: []'
Serial.print(F("fooString is: ["));
Serial.print(fooString);
Serial.println(F("]")); // will show 'fooString is: []'
void loop() {}
You'll see the length of the cString is 0 - which means 1 byte was allocated the trailing NULL that is part of the standard.
console will show
[color=purple]
0
Buffer is: []
fooString is: []
[/color]
