I have a string of length 32. After using substring command, I have chopped the string into substrings of length 4 each.
Now I have 0100 0100 1010 like strings. I just want to convert these substrings as their HEX equivalents. Like 0100 == 4
1010 == A etc.
I am unable to take the HEX equivalents of these substrings. Can anyone help me in sorting out this problem?
guix
June 17, 2015, 5:10pm
2
Hello and welcome,
Here is one efficient way to do it
char nibbleStringToHexChar( const char *s )
uint8_t n = 0;
while ( *s )
n = ( n << 1 ) + ( *s++ == '1' );
return ( n > 9 ) ? ( n-10 + 'A' ) : ( n + '0' );
Serial.println( nibbleStringToHexChar( "1100" ) );
Edit: changed char * to const char *.
Thanks for your response. However when I run your code in Arduino intact, it gives the error
"'Serial' does not name a type".
Your response is awaited.
guix
June 17, 2015, 7:08pm
4
It isn't a complete code, you can't run it. It's a function and below it, an example of how to use that function. Your job is to copy/paste the function in your own sketch, and use it wherever and however you want
Here is a complete example if you really want it..
uint8_t n = 0;
while ( *s )
Serial.begin( 9600 );
I've just tested and it outputs 'C' as expected.
O.K. I got your point. But it would be better if you could signify the presence of "1100" in Serial.println line.
Hope you understand.
system
June 17, 2015, 7:23pm
6
What does this mean? Signify how? You wrote the value to the output buffer. You know its there. What is the problem?
