string to byte
Hello,
I know that this topic has been raised before, however, I failed to find the answer i am looking for.
I have the following string:
String S = "0b00001111";
I need it to become the following byte
byte B = 0b00001111;
so that I can later put it into the following array
byte B_array [8] = (0b000000000,
                             0b000000000,
                             0b000000000,
                             0b000000000,
                             0b000000000,
                             0b000000000,
                             0b000000000,
                             0b000000000);
I have already tried this:
B = byte (S.toInt());
and it doesn't work as expected - it just creates a single integer out of the String. (or better it actually works as it says but this is not what I want it to do.
B = byte (S); doesn't work either
I don't think there exists such a function. So you have to interpret it yourself.
Ok, fine, however, is there a way to add bits to a byte? Can I use byte as an array of sorts?
byte B = 0b00011111;
B[2] = 1;
B = 0b10011111;
String s = "0b00110011";
byte b = Byte.parseByte(s);
Throws NumberFormatException if the string cannot be parsed.
What's wrong with bitWrite.
Why are you using a String in the first place? Where does the value in the resource-wasting String come from? Sending data intelligently is better than struggling to convert the crap you get to the form you want.
strinda:
There are ways to add, subtract, shift left, shift right, AND, OR, NAND, NOR, XAND, XOR etc. bits in a byte. You can use a struct to declare names for the bits in a byte, and access them by name.
