Hey everyone
I'm trying for a project to pass a large string of ones and zeros through PubNub
The function works as follows:
char msg[] = "\"arduino-WiFi101-hello-world!\"";
WiFiClient* client = PubNub.publish(channel, msg);
if (!client) {
Serial.println("publishing error");
return;
client->stop();
The problem is also that I haven't really worked with such char arrays yet. It does work if I give the msg variable this value:
char msg[] = "\"0110110111010101100\""; //random combination
I can save the data as a String or bool array, but if I then publish it this way, I automatically receive a number of, so 1.101101110101e5 via pubnub.
int length = Data.length()+1;
char charArray[length];
Data.toCharArray(charArray, length);
This is definitely not what I mean. Does anyone know what I can do?
Here I form a String and publish:
powerInfo.concat( String(CalculatedVoltage,2) );
xSemaphoreGive( sema_CalculatedVoltage );
powerInfo.concat( ",");
powerInfo.concat( String(mA,2) );
powerInfo.concat( String(Power,4) );
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
MQTTclient.publish( topicPower, powerInfo.c_str() );
Might give you a clue.
Oh yes thanks. With concat I was able to add the bits and the quote at the end by:
String bits = "\"";
//add some bits...
bits.concat("\"");
and then send it with that c_str () function
WiFiClient* = PubNub.publish(channel, bits.c_str()); // Publish message.
drmpf
4
If you are using Arduino Strings, check out my tutorial on
Taming Arduino Strings - How to avoid memory issues
system
Closed
5
