String value to char const value convert...how?
on Arduino code...
I defined apname as String.
String apName = "es88";
and on Setup() method.
WifiManager.autoconnect(apName);
but auto connect method 's first parameter should be char const.
so. If I run above code, I have error saying
no know conversion for argument 1 from 'String' to 'const char*'
How can I define globally and use it ?
kotran:
on Arduino code...
that's a bad idea :slight_smile: - don't use the String class on small micro-controllers
an array of char of a pointer to a char cstring would do...
kotran:
see.. you would not have had the issue :slight_smile:
kotran:
use ... const char * apName = "es88";orconst char apName[] = "es88";
You need to learn about c-strings: arrays of char terminated by ‘\0’. This is the standard way of doing strings in the C programming language (C before C++ was invented).
libc, which is part of the arduino build environment, contains several functions used to deal with this type of string
The documentation is here.
