Make a test sketch and play with it
It's what I usually do (more or less).
Thanks guys for your help! Did learn much I did'nt know!
sterretje:
Make a test sketch and play with itIt's what I usually do (more or less).
But for me personally I need to understand the bigger picture first.
That's what I came up with. Any ideas on it (besides the size of the array)?
There are max 56 sensors so I'm not that happy with:
for (int i = 0; i < 60; i = i + 10)
but it works.
// ----- Error Email Body definition ------------------------------------------------------
#define Zeile1 "\nLETZTE MESSWERTE:\n\n"
#define ZWass "Wasserstand Tank: "
// #define ZDWass "Wasserstand DĂźngermix: " // Erstmal ausgelassen
#define ZTemp "Temperatur (°C): "
#define ZLight "Helligkeit: "
#define ZSensTitle "\n\nFeuchtigkeitssensoren:\n"
#define ZTrenn "___________________________________________________________\n"
#define ZPot "Topf: "
#define ZRead "Messwert:"
#define ZHinw "Hinweis: Sensorfehler oder fehlende Kalibration = -1"
int AnzToepfe = 56;
int WassMAP = 100;
int Temperatur = 25; // durch ReadTemp(); ersetzen
int Helligkeit = 70; // durch gemappte Helligkeit ersetzen
char MailString[2048] = {}; // Mailinhalt
int FeuchtigkeitMAP[56] = {
100, 200, 300, 400, 500, 600, 700, 800,
900, 110, 120, 130, 140, 150, 160, 170,
180, 190, 210, 220, 230, 240, 250, 260,
270, 280, 290, 310, 320, 330, 340, 350,
360, 370, 380, 390, 410, 420, 430, 440,
450, 460, 470, 480, 490, 510, 520, 530,
540, 550, 560, 570, 580, 590, 610, 620
sprintf(MailString, Zeile1 ZWass "%d\n" ZTemp "%d\n" ZLight "%d\n" ZSensTitle ZTrenn, WassMAP, Temperatur, Helligkeit);
if (i < AnzToepfe)
sprintf(MailString + strlen(MailString), ZPot);
for (int j = 0; j < 10; j++)
if (j + i < AnzToepfe)
sprintf(MailString + strlen(MailString), "%5d" , j + i + 1);
sprintf(MailString + strlen(MailString), "\n" ZRead);
sprintf(MailString + strlen(MailString), "%5d" , FeuchtigkeitMAP[0 + j + i]);
sprintf(MailString + strlen(MailString), "\n" ZTrenn);
sprintf(MailString + strlen(MailString), "\n\n" ZHinw);
Serial.println("\n\n\n---------------------------------------------------------------------------------------------");
Serial.print("String Länge: ");
Serial.println(strlen(MailString));
Serial.println("String: ");
Serial.println("---------------------------------------------------------------------------------------------");
printf(MailString);
delay(10000);
Gorkde:
I noticed buffer is marked by Arduino IDE
The reason is the Bridge library has a buffer function so it's in that library's keywords.txt. This has no relevance to your code but the Arduino IDE still highlights it.
