string without "" on max
hi
i'm new on arduino and programming...
to get sensor on Max/msp with an ethernet shield i used Z_osc. for get value in good type i have convert long to string (to have value between 0/1023).
but max interpreted a string like a symbol = /sensor "422" and i have to remove the " " for each input adress.
is there a way to have value between 0/1023 without the " " .
below the code i used
thanks for your help
0-0
#include <SPI.h>
#include <Ethernet.h>
#include <Z_OSC.h>
byte myMac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0x32, 0x78 };
byte myIp[]  = { 192, 168, 0, 255 };
byte destIp[] =  { 192, 168, 0, 5 }; //IP ordi
int  destPort = 10000; //port receive
char oscAdr[] = "/sensor";
int  sensorPin = A0;
int  sensorValue = 0;
char bufPin0[5];
Z_OSCClient client;
void setup(){
  Ethernet.begin(myMac ,myIp);
void loop(){
  sendProcess();
  Z_OSCMessage mes;
  mes.setAddress(destIp,destPort);
  client.send(&mes);
  mes.flush();
  delay(10);
void sendProcess(){
  int tmp= (int) sensorValue;
  Z_OSCMessage message;
  message.setAddress(destIp,destPort);
  message.setZ_OSCMessage(oscAdr ,"s" ,&bufPin0 );
  client.send(&message);
sensorValue = analogRead (sensorPin);
itoa (sensorValue-0, bufPin0, 10); //convert long into string
I think this is how you send a number without the quotes:
void sendProcess(){
  long tmp = sensorValue;
  message.setZ_OSCMessage(oscAdr ,"i" ,&tmp );
YEs... thanks a lot...
best
