stringing 2 shift registers for midi controller use
I am having trouble with the process of shifting bits into a second shift register. im totally lost on this. ive attached my code… how far off am i?
pianomat.ino (2.96 KB)
// Pin Definitions
// Rows are connected to
const int row1 = 5;
const int row2 = 6;
// The 74HC595 uses a serial communication
// link which has three pins
const int clock = 9;
const int latch = 10;
const int data = 11;
uint16_t keyToMidiMap[27];
boolean keyPressed[27];
int noteVelocity = 127;
// use prepared bit vectors instead of shifting bit left everytime
long long int bits = { 0000000000000001, 0000000000000010, 0000000000000100, 0000000000001000, 0000000000010000, 0000000000100000, 0000000001000000, 0000000010000000, 0000000100000000, 0000001000000000, 0000010000000000, 0000100000000000, 0001000000000000, 0010000000000000, 0100000000000000, 1000000000000000 };
// 74HC595 shift to next column
void scanColumn(int value) {
digitalWrite(latch, LOW); //Pulls the chips latch low
shiftOut(data, clock, MSBFIRST, value); //Shifts out the 8 bits to the shift register
digitalWrite(latch, HIGH); //Pulls the latch high displaying the data
// Map scan matrix buttons/keys to actual Midi note number.
keyToMidiMap[0] = 53;
keyToMidiMap[1] = 55;
keyToMidiMap[2] = 57;
keyToMidiMap[3] = 59;
keyToMidiMap[4] = 60;
keyToMidiMap[5] = 62;
keyToMidiMap[6] = 64;
keyToMidiMap[7] = 65;
keyToMidiMap[8] = 67;
keyToMidiMap[9] = 69;
keyToMidiMap[10] = 71;
keyToMidiMap[11] = 72;
keyToMidiMap[12] = 74;
keyToMidiMap[13] = 76;
keyToMidiMap[0 + 14] = 54;
keyToMidiMap[1 + 14] = 56;
keyToMidiMap[2 + 14] = 58;
keyToMidiMap[4 + 14] = 61;
keyToMidiMap[5 + 14] = 63;
keyToMidiMap[8 + 14] = 66;
keyToMidiMap[9 + 14] = 68;
keyToMidiMap[10 + 14] = 70;
keyToMidiMap[12 + 14] = 73;
keyToMidiMap[13 + 14] = 75;
// setup pins output/input mode
pinMode(data, OUTPUT);
pinMode(clock, OUTPUT);
pinMode(latch, OUTPUT);
pinMode(row1, INPUT);
pinMode(row2, INPUT);
Serial.begin(31250);
for (int col = 0; col < 14; col++) {
// shift scan matrix to following column
scanColumn(bits[col]);
// check if any keys were pressed - rows will have HIGH output in this case corresponding
int groupValue1 = digitalRead(row1);
int groupValue2 = digitalRead(row2);
// process if any combination of keys pressed
if (groupValue1 != 0 || groupValue2 != 0) {
if (groupValue1 != 0 && !keyPressed[col]) {
keyPressed[col] = true;
noteOn(0x91, keyToMidiMap[col], noteVelocity);
if (groupValue2 != 0 && !keyPressed[col + 14]) {
keyPressed[col + 14] = true;
noteOn(0x91, keyToMidiMap[col + 14], noteVelocity);
// process if any combination of keys released
if (groupValue1 == 0 && keyPressed[col]) {
keyPressed[col] = false;
noteOn(0x91, keyToMidiMap[col], 0);
if (groupValue2 == 0 && keyPressed[col + 14]) {
keyPressed[col + 14] = false;
noteOn(0x91, keyToMidiMap[col + 14], 0);
void noteOn(int cmd, int pitch, int velocity) {
Serial.write(cmd);
Serial.write(pitch);
Serial.write(velocity);
