Strings and saving memory...
I am fairly new to c and Arduino. On other non Arduino micros I am able to save memory space by putting strings in constants and/or variables and save several bytes of program memory. When I attempt to do the same, I consume more memory. Why?
Here are two examples I am using as an example. The first is how most users display strings on serial console. The second should technical save about 96 bytes of memory but it consumes KB more memory.
Program 1
  Serial.begin(115200); // open the serial port
  Serial.print("The Arduino microcontroller is a fun microcontroller to learn to program in C.\n");
  Serial.print("The Arduino microcontroller has 32kb storage for programs.\n");
  Serial.print("The Arduino microcontroller is a microcontroller that helps people learn electronics as well.\n");
Program 2
  String sArduino = "Arduino"; // 7 bytes
  String sMicrocontroller = "microcontroller"; // 15 bytes
  Serial.print("The " + sArduino + " " + sMicrocontroller + " is a fun " + sMicrocontroller + " to learn to program in C.\n");
  Serial.print("The " + sArduino + " " + sMicrocontroller + " has 32kb storage for programs.\n");
  Serial.print("The " + sArduino + " " + sMicrocontroller + " is a " + sMicrocontroller + " that helps people learn electronics as well.\n");
  // total savings should be 96 bytes
Am I not declaring the strings properly or will the total equivalent string data need to have significantly more text to show any savings. Other micros, non c, are ably to show a savings of memory/flash. Am I doing this wrong in C?
Thank you in advance for your response!
Why not simply use the "F" macro? instead of:
Serial.print(F("The Arduino microcontroller is a fun microcontroller to learn to program in C.\n"));
That is all there is to it.
Ive thought and tried the same thing and nothing much changes. I figured it was because of some block allocation concept in use such that you have save a whole block before seeing a change.
Your second example uses the String class, which adds a considerable amount of code that must then be stored in the flash (program) memory. Using the F() macro with the code from the first example will save a considerable amount of dynamic memory, but use a bit more flash memory because of the extra code needed by the print function to handle strings stored in flash memory.
You can optimize it a bit because of the identical text at the start of each line, but not really worth the effort unless you are drastically short on memory.
  static const char text1[] PROGMEM = "The Arduino microcontroller ";
  Serial.print((__FlashStringHelper*)text1);
  Serial.print(F("is a fun microcontroller to learn to program in C.\n"));
  Serial.print(F("has 32kb storage for programs.\n"));
  Serial.print(F("is a microcontroller that helps people learn electronics as well.\n"));
I tested it and it does work, but what on earth is __FlashStringHelper* and where does it come from and are there any more of them?
sevenoutpinball:
It's just a pointer to a specific data type, so that the print routines can be overloaded to cope with strings in flash memory.
What does the F() do exactly? - Programming Questions - Arduino Forum. seems to cover this exhaustively.
is there any advantage to using something like this
#include <iostream>
using namespace std;
class printData {
   public:
      void print(int i) {
        cout << "Printing int: " << i << endl;
      void print(double  f) {
        cout << "Printing float: " << f << endl;
      void print(char* c) {
        cout << "Printing character: " << c << endl;
int main(void) {
   printData pd;
   // Call print to print integer
   pd.print(5);
   // Call print to print float
   pd.print(500.263);
   // Call print to print character
   pd.print("Hello C++");
   return 0;
here in arduinoland?
