Store.ino: In function 'void loop()':
Store:36: error: case label does not reduce to an integer constant
Store:41: error: case label does not reduce to an integer constant
Store:46: error: case label does not reduce to an integer constant
Store:51: error: case label does not reduce to an integer constant
Store:56: error: case label does not reduce to an integer constant
Store:61: error: case label does not reduce to an integer constant
Store:66: error: case label does not reduce to an integer constant
Store:72: error: case label does not reduce to an integer constant
Store:77: error: case label does not reduce to an integer constant
Store:82: error: case label does not reduce to an integer constant
Store:87: error: case label does not reduce to an integer constant
Store:92: error: case label does not reduce to an integer constant
Store:97: error: case label does not reduce to an integer constant
Store:102: error: case label does not reduce to an integer constant
Store:107: error: case label does not reduce to an integer constant
Store:112: error: case label does not reduce to an integer constant
Store:117: error: case label does not reduce to an integer constant
Store:122: error: case label does not reduce to an integer constant
Store:127: error: case label does not reduce to an integer constant
Store:132: error: case label does not reduce to an integer constant
Store:137: error: case label does not reduce to an integer constant
Store:142: error: case label does not reduce to an integer constant
Store:147: error: case label does not reduce to an integer constant
enabled in File > Preferences.
'rack' is a variable capable of holding a single character, so only will contain T or O or P (for your example).
The switch statement will only work with a numeric variable (1, 2, 'a', 'b' etc).
So for top, you can simply send a 'T'
switch(rack)
case 'T':
I would start reading Robin2's Serial Input Basics - updated if you want to make it more complicated than single character. You can make use of strcmp in combination with if / else if
// make sure rack is large enough to hold your largets message plus one additional character
char rack[10];
//read characters into rack variable; up to you
// check and take action
if(strcmp(rack, "TOP") == 0)
else if(strcmp(rack, "BOTTOM") == 0)
else if
etc
etc
etc
No matter how much you want to do it that way you CAN'T use a string in a switch statement in C, get over it an move on. I wanted to be an astronaut, I couldn't so I got over it, you need to do the same and find some valid C code to do what you want.
Either compromise and use a single character like 'T', or use the strcmp() function in an if{} as noted above.
Even if you could use a string like "TOP" you are only reading a single character, but you can't so forget I mentioned that.
