stripping down Arduino-IDE for quickest possible starting
Hi everybody,
I want to adjust the colorscheme of the Arduino-IDE. It seems that a new start is nescessary each time if a color-value has been changed. Though my usual Arduino-IDE has quite a lot of additional libraries which slow down the start of the IDE.
For adjusting the colors I would like to have a version of the Arduino-IDE that starts as quick as possible
So what folders can I delete and the IDE will still start?
Or is there another way of re-viewing changed colors?
best regards Stefan
A quick way to get a minimal installation of the Arduino IDE is to run it in portable mode:
That will cause it to no longer use the standard folders that contain Boards Manager installed boards and sketchbook.
Some other tips might include
1)
Do not check for updates
2)
Remove (temporarily) all installed libraries from the libraries directory.
Hi pert and steretje,
thank you for answering. Somehow I'm doing something wrong with the portable installation
My portable installation does not work independent of the Arduino-"standard"-installation
I downloaded the file arduino-1.8.13-portable.zip into the folder
D:\Test-Arduino
Then I u used 7zip to unzip into folder
D:\Test-Arduino\arduino-1.8.13-portable
I changed to folder
D:\Test-Arduino\arduino-1.8.13-portable\arduino-1.8.13
where the Arduino.exe is located
E:\Test\arduino-1.8.13-Farbtest\arduino-1.8.13\arduino.exe
If I start this arduino.exe and open preferences I can see that it uses the file
C:\Users\Stefan\AppData\Local\Arduino15\preferences.txt
which is my standard-installation.
So something additional has to be done that the
is using the preferences.txt-file that is located here
E:\Test\arduino-1.8.13-Farbtest\arduino-1.8.13\lib\preferences.txt
or whereever it must be located to make it working really independent.
best regards Stefan
StefanL38:
I've never heard of this file before. Where did you download it from it?
StefanL38:
I changed to folder
You forgot to do the one essential step from the instructions: create a folder named portable unside the Arduino IDE installation folder. Without that folder, it's just a normal Arduino IDE installation.
So you need to create the folder E:\Test\arduino-1.8.13-Farbtest\arduino-1.8.13\portable
Hi pert,
thank you very much for pointing me to the missing detail.
Yes now it works.
For almost any Opensource-software there is a portable version as an extra ZIP-file.
It would be very easy to ZIP the portabel-version with the requiered folders as there are
"portable"
and subdirectories
"sketchbook",
"libraries"
and
"packages"
So that unzipping creates all subfolders that are needed
best regards Stefan
@StefanL38, I was thinking the same.
But I suspect that it's not only the 'portable' mode that this is used for. I think that it can also be used by users that don't have administrative permissions on their machines and don't have the need for the 'portable' mode.
