Strtok needs a literal delimiter?
Hi guys. Just checking to see if this is C++ according to Hoyle or just a quirk with Arduino flavor.
If I write this:
const char Delimiter=':';
 //Declare array and get first token.
    Token=strtok(receivedChars,Delimiter);
I get broken data. I also tried these declarations for Delimiter:
char Delimiter;
String Delimiter;
char * Delimiter; //you never know. ;)
But strtok only works if I do it like so:
Token=strtok(receivedChars,":");
Which is fine, but I was just wondering if this is expected for strtok in general.
I'm using this for my reference.
Edit, sry: same thing applies to the second argument...
It's very clear. The first argument is
 char *str
pointer to char.
If you had included what you have in front of you for the declaration of
receivedChars
you would see, I think, that it is a point to char, or a character array, same same in C/C++.
So no getting creative. Use the argument types in the documentation.
a7
You can have multiple delimiters that’s why you pass a cString pointer so using double quotes even if you only have one.
const char * delimiters = ":";
Or you could use
const char delimiters[] = ":";
consider some generic code that tokenizes and convert numerics to values
char s [80];
#define MaxTok  10
char *toks [MaxTok];
int   vals [MaxTok];
int
tokenize (
    char       *s,
    const char *sep )
    unsigned n = 0;
    toks [n] = strtok (s, sep);
    vals [n] = atoi (toks [n]);
    for (n = 1; (toks [n] = strtok (NULL, sep)); n++)
    return n;
void dispToks (
    char * toks [])
    char s [40];
    for (unsigned n = 0; toks [n]; n++)  {
        sprintf (s, " %6d  %s", vals [n], toks [n]);
        Serial.println (s);
void loop ()
    if (Serial.available ())  {
        int n = Serial. readBytesUntil ('\n', s, sizeof(s)-1);
        s [n] = 0;      // terminate string
        tokenize (s, ",");
        dispToks (toks);
void setup ()
    Serial.begin (9600);
Because the second argument to strtok() is:
delim − This is the C string containing the delimiters.
You are passing a single character constant, not a C string which is a character pointer pointing to the first of zero or more characters ending in a null ('\0') character.
You can pass a constant C string several ways:
#define Delimiter ":"
or
const char *Delimiter = ":";
or
const char Delimiter[] = ":";
