Strtok() questions
I have a string coming into serial
+CLIP: "1234567890",129,"",0,"",0
I wanna use strtok with delimiter ". How can i use strtok to search for " since using const char delimiter[] = " " "; will output this error: Compilation error: missing terminating " character
thanks
Hello dummyguy
Welcome to the worldbest Arduino forum ever.
Post your sketch, well formated, with well-tempered comments and in so called
code tags "< code >" to see how we can help.
I have no code... i m just testing different ways of parsing that incoming string ... strtok looks very good but how to use " is what i got in trouble with.
Me too.
i bet if i give you a bit of code you go afk !
i don t have any issue with a specific code ... i asked how can i use " delimiter in a strtok function. looks like you read questions same way how you answear...
char * strtok ( char * str, const char * delimiters );
Split string into tokens
Try: delimiter[] = " " ";
not working ... tried that 1st thing :slight_smile:
what seems to work but i don t know if is right ... is const char delimiter[] = " \ " \ " "; without spaces inside "" used spaces here on forum
Unfortunately I forgot the code tags and the forum changed what I wrote:
delimiter[] = " \" ";
as you posted will not create tokes with " delimiter... idk why my version works ...
oh yes... sorry it works your version too ... if you kind can you explain how my version works too ?:)))
The \ prevents the compiler from interpreting the " as a string ending.
googled about it and got so confused... your answer is in beginner terms! tx a lot , i understand now!
You're welcome.
Indeed.
The \ is known as the escape character - it is used for creating a number of things that you can't just type:
