Hi All,
To keep things simple I wont explain my whole project just yet, but you need to know that I'm trying to write a library to control some LIFX WiFi bulbs.
They have a LAN protocol that uses udp packets with little-endian encoding.
The udp packet is broken up into header and payload, for now I'm only working on getting the header added to the udp packet correctly and I'am working on a Arduino UNO (WiFi shield in the post).
what I have so far (Disclaimer: I'm not a c++ programmer and am learning this as I go, Things could be very wrong.)
Main.ino
#include "device.h"
device Device(Serial);
/* Find Devices */
Device.GetService();
/* Control Light */
device.h
#ifndef device_h
#define device_h
/* includes */
#include <Stdint.h>
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
class device{
public:
/* Member Functions */
device(Stream& serial);
void GetService();
/* Members */
#pragma pack(push, 1)
typedef struct {
/* frame */
uint16_t size;
uint8_t origin:2;
uint8_t tagged:1;
uint8_t addressable:1;
uint16_t protocol:12;
uint32_t source;
/* frame address */
uint8_t target[8];
uint8_t reservedA[6];
uint8_t reservedB:6;
uint8_t ack_required:1;
uint8_t res_required:1;
uint8_t sequence;
/* protocol header */
uint64_t reservedC;
uint16_t type;
uint16_t reservedD;
} Header;
#pragma pack(pop)
private:
/* Members */
// _Udp;
Stream *_serial;
enum msg{
_GetService = 2,
_StateService = 3,
_GetHostInfo = 12,
_StateHostInfo = 13,
_GetHostFirmware = 14,
_StateHostFirmware = 15,
_GetWifiInfo = 16,
_StateWifiInfo = 17,
_GetWifiFirmware = 18,
_StateWifiFirmware = 19,
_GetPower = 20,
_SetPower = 21,
_StatePower = 22,
_GetLabel = 23,
_SetLabel = 24,
_StateLabel = 25,
_GetVersion = 32,
_StateVersion = 33,
_GetInfo = 34,
_StateInfo = 35,
_Acknowledgement = 45,
_EchoRequest = 58,
_EchoResponse = 59
#endif
device.cpp
#include "device.h"
device::device(Stream& serial) : _serial(&serial)
/* debug serial interface */
void device::GetService()
/* header */
Header header;
int headerSize = sizeof(header);
/* payload */
// N/A
/* UDP Packet */
uint8_t udpPacket[sizeof(header)];
/* Debug */
byte *ptr = (byte*) &header;
_serial->print("Header Before:");
for (int i = 0; i < sizeof(header) ; i++){
//_serial->print(i);
//_serial->print(":");
//_serial->print("0x");
if (*ptr < 16)
_serial->print("0");
_serial->print(*ptr++,HEX);
_serial->print(" ");
_serial->println("");
/* build header */
header.size = sizeof(header);
header.origin = 0;
header.tagged = 1;
header.addressable = 1;
header.protocol = 1024;
header.source = 0;
header.target[0] = 0;
header.target[1] = 0;
header.target[2] = 0;
header.target[3] = 0;
header.target[4] = 0;
header.target[5] = 0;
header.target[6] = 0;
header.target[7] = 0;
header.reservedA[0] = 0;
header.reservedA[1] = 0;
header.reservedA[2] = 0;
header.reservedA[3] = 0;
header.reservedA[4] = 0;
header.reservedA[5] = 0;
header.reservedB = 0;
header.ack_required = 0;
header.res_required = 0;
header.sequence = 0;
header.reservedC = 0;
header.type = _GetService;
header.reservedD = 0;
_serial->print("Header After: ");
if (*ptr < 16)
/* build payload */
// N/A
/* build udp packet */
memcpy(&udpPacket, &header, sizeof(header));
/* Debug */
_serial->print("Device UDP Packet:");
for (int i = 0; i < sizeof(udpPacket) ; i++){
// _serial->print(i);
if (udpPacket[i] < 16)
_serial->print(udpPacket[i],HEX);
Debug Log (Added in the Expecting lines):
Header Before:24 00 0C 40 00 03 48 01 C5 01 C5 03 04 01 0A 00 02 00 00 23 A3 00 02 65 00 01 49 00 01 03 48 00 C1 01 C5 00
(Expecting: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00)
Header After: 00 68 00 80 7F 00 00 00 03 05 11 01 03 9B 00 5C 48 65 61 64 65 72 20 42 65 66 6F 72 65 3A 00 30 00 48 65 61
(Expecting: 24 00 00 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00)
Device UDP Packet:24 00 0C 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00
From what I have read the UNO is little-endian by default (don't know if you can change it?) so storing a uint16_t of 0xABCD in memory should store as 0xCDAB.
so working on that theory if I build a struct with defined types I should get the little-endian encoding I'm looking for and should be able to copy it to the udp packet without any changes.
so my questions:
Why is the before header print showing values?
Why is the after header print not showing the correct values?
Why is the UDP packet so close but this not correct?
I have a theory on the UDP been close, it has something to do with the way I have done the bit packing in the strut e.g.
Struct:
uint8_t origin:2;
uint8_t tagged:1;
Set to:
header.origin = 0;
header.tagged = 1;
I thought in memory that would be 0x00 0x34 but it is coming out as 0x0C 0x40, so I don't think it's packing the way I think it should.
As for the other two problems I just don't know yet, maybe it's the way I'm printing the debug??
any insight would be greatly appreciated, again I'm learning this on the fly give me all the pointers you have :).
