Struct member changes are reset
Hi All,
In my project I need to define a struct to carry data regarding some "channel". I want to store 4 pin numbers for the channel and some additional info. Then I want to have an array of channels. In my first prototype I'll use Pro Mini which can have up to 4 channels. I plan do have variable number of channels so array of channel structs seems to be best for me.
My issue comes when I change fields/properties of my struct in loop(). Next time loop() is called the modified member gets reset to original value which I put there in setup(). I feel like I need to use pointers, I tried but it didn't worked. Here's my code:
#define CHANNEL_NUMBER 4
#define START_PIN 2
struct ChannelStruct
  byte id;
  byte measurePin;
  byte load1Pin;
  byte load2Pin;
  byte finishPin;
  byte lastVoltageIndex;
typedef struct ChannelStruct Channel;
Channel channels[CHANNEL_NUMBER];
  Serial.println("setup");
  for (byte i=0; i < CHANNEL_NUMBER; i++)
    byte channelStartPin = START_PIN + i * 3;
    Channel c;
    c.id = i;
    c.measurePin = i;
    c.load1Pin = channelStartPin;
    c.load2Pin = channelStartPin + 1;
    c.finishPin = channelStartPin + 2;
    c.lastVoltageIndex = 255;
    channels[i] = c;
    Serial.print("Channel ID: "); Serial.println(i);
    Serial.print("Address: "); Serial.println((int) &c);
  Serial.println("loop");
    Channel c = channels[i];
    if (c.lastVoltageIndex == 255)
      c.lastVoltageIndex = 0;
      Serial.print("Channel ID: "); Serial.println(c.id);
      Serial.println("Init");
In setup() I put lastVoltageIndex = 255 which I use as a flag that this channel is not initialized. In the loop I'm checking if lastVoltageIndex == 255 and if so I want to do some init (not included here) and update struct field to 0 so that init will never happen again. What happens is Init is called every time because lastVoltageIndex is always 255.
Please advice. I went through reference and through all struct related threads on the forum. I'm not good at C++. I'm using C# for 10+ years but it does not help now :slight_smile:
You never assign "c" back.
If anything, struct in C/C++ is similar to struct in C#, it is passed by value.
Wow, thank you so much! It works now :slight_smile:
Use pointers to the structs in the array:
#define START_PIN 2
struct Channel
  byte id;
  byte measurePin;
  byte load1Pin;
  byte load2Pin;
  byte finishPin;
    Channel *c = &channels[i];
    c->id = i;
    c->measurePin = i;
    c->load1Pin = channelStartPin;
    c->load2Pin = channelStartPin + 1;
    c->finishPin = channelStartPin + 2;
    c->lastVoltageIndex = 255;
    Serial.print("Address: "); Serial.println((int)c);
    if (c->lastVoltageIndex == 255)
      c->lastVoltageIndex = 0;
      Serial.print("Channel ID: "); Serial.println(c->id);
