I tried using the "I2Cdev" and "MPU6050_6Axis_MotionApps20.h" libraries to get measurements from MPU6050 accelerometer in arduino UNO and the Arduino editor returned me the following warning:
sketch\MPU6050.h:436:7: warning: type 'struct MPU6050' violates one definition rule [-Wodr]
class MPU6050 {
sketch\MPU6050.h:436:7: note: a different type is defined in another translation unit
class MPU6050 {
sketch\MPU6050.h:1026:18: note: the first difference of corresponding definitions is field 'dmpPacketBuffer'
uint8_t *dmpPacketBuffer;
sketch\MPU6050.h:436:7: note: a type with different number of fields is defined in another translation unit
class MPU6050 {
The program compiles and it generates the interrupt signal but it does not send me the data correctly (the return messages have no meaning, it's like ASCII characters)
I think there is a parameter declared two time in the library. But I can't find exactly what is the problem
If some one did before, thank you for advice
