struct typedef compilation error
When I try to compile this test case with 1.5.2 for a Due:
typedef struct {
  int aMember;
} MyStruct;
MyStruct* pInstance;
void dumpStruct(MyStruct* m)
  dumpStruct(pInstance);
… I get:
ArduinoSPBM:3 error: variable or field 'dumpStruct' declared void
ArduinoSPBM:3 error: 'MyStruct' was not declared in this scope
ArduinoSPBM:3 error: 'm' was not declared in this scope
Line 3 is the structure member ‘aMember’.
It compiles OK with g++ with main() calling setup().
What am I doing wrong?
Thanks…
Its an issue with how Arduino IDE handles the function prototypes (puts them at the top).
typedef struct {
  int aMember;
} MyStruct;
void dumpStruct(MyStruct* m);
Manually added the function prototype and it compiles.
Thanks, that was it. Why doesn't it apply to functions with only primitive arguments?
gutbag: Thanks, that was it. Why doesn't it apply to functions with only primitive arguments?
No idea, that's just how the Arduino guys coded it.
gutbag: Why doesn't it apply to functions with only primitive arguments?
Because the IDE 'feature' that generates automatic function prototypes was not designed properly.
