Struct variables Question.
How do i pull the variable out from the Struct which is in a library to the Void loop which is the hello_world file.
and than make use of the variable height, x, y, width to set a condition
i have attach all the files below .
This is the last attach file because there isn’t space
// begin license header
// This file is part of Pixy CMUcam5 or "Pixy" for short
// All Pixy source code is provided under the terms of the
// GNU General Public License v2 (http://www.gnu.org/licenses/gpl-2.0.html).
// Those wishing to use Pixy source code, software and/or
// technologies under different licensing terms should contact us at
// cmucam@cs.cmu.edu. Such licensing terms are available for
// all portions of the Pixy codebase presented here.
// end license header
  06.04.2014 v0.1.3 John Leimon
    + Added init() for initializing Pixy, which should
      be called from the setup() function. See comment
      in Pixy.h for details.
#ifndef _TPIXY_H
#define _TPIXY_H
#include "Arduino.h"
#define PIXY_INITIAL_ARRAYSIZE      30
#define PIXY_MAXIMUM_ARRAYSIZE      130
#define PIXY_START_WORD             0xaa55
#define PIXY_START_WORDX            0x55aa
#define PIXY_DEFAULT_ADDR           0x54  // I2C
struct Block
  void print()
    char buf[64];
    sprintf(buf, "sig: %d x: %d y: %d width: %d height: %d\n", signature, x, y, width, height);
    Serial.print(buf);
  uint16_t signature; // unsigned signature
  uint16_t x;
  uint16_t y;
  uint16_t width;
  uint16_t height;
template <class LinkType> class TPixy
public:
  TPixy(uint8_t addr=PIXY_DEFAULT_ADDR);
  ~TPixy();
  uint16_t getBlocks(uint16_t maxBlocks=1000);
  int8_t setServos(uint16_t s0, uint16_t s1);
  void init();
  Block *blocks;
private:
  boolean getStart();
  void resize();
  LinkType link;
  boolean  skipStart;
  uint16_t blockCount;
  uint16_t blockArraySize;
template <class LinkType> TPixy<LinkType>::TPixy(uint8_t addr)
  skipStart = false;
  blockCount = 0;
  blockArraySize = PIXY_INITIAL_ARRAYSIZE;
  blocks = (Block *)malloc(sizeof(Block)*blockArraySize);
  link.setAddress(addr);
template <class LinkType> void TPixy<LinkType>::init()
  link.init();
template <class LinkType> TPixy<LinkType>::~TPixy()
  free(blocks);
template <class LinkType> boolean TPixy<LinkType>::getStart()
  uint16_t w, lastw;
  lastw = 0xffff;
  while(true)
    w = link.getWord();
    if (w==0 && lastw==0)
      delayMicroseconds(10);
	  return false;
    else if (w==PIXY_START_WORD && lastw==PIXY_START_WORD)
      return true;
	else if (w==PIXY_START_WORDX)
	  Serial.println("reorder");
	  link.getByte(); // resync
	lastw = w;
template <class LinkType> void TPixy<LinkType>::resize()
  Block *newBlocks;
  blockArraySize += PIXY_INITIAL_ARRAYSIZE;
  newBlocks = (Block *)malloc(sizeof(Block)*blockArraySize);
  memcpy(newBlocks, blocks, sizeof(Block)*blockCount);
  free(blocks);
  blocks = newBlocks;
template <class LinkType> uint16_t TPixy<LinkType>::getBlocks(uint16_t maxBlocks)
  uint8_t i;
  uint16_t w, checksum, sum;
  Block *block;
  if (!skipStart)
    if (getStart()==false)
      return 0;
	skipStart = false;
  for(blockCount=0; blockCount<maxBlocks && blockCount<PIXY_MAXIMUM_ARRAYSIZE;)
    checksum = link.getWord();
    if (checksum==PIXY_START_WORD) // we've reached the beginning of the next frame
      skipStart = true;
	  //Serial.println("skip");
      return blockCount;
    else if (checksum==0)
      return blockCount;
	if (blockCount>blockArraySize)
		resize();
	block = blocks + blockCount;
    for (i=0, sum=0; i<sizeof(Block)/sizeof(uint16_t); i++)
      w = link.getWord();
      sum += w;
      *((uint16_t *)block + i) = w;
    if (checksum==sum)
      blockCount++;
      Serial.println("cs error");
	w = link.getWord();
    if (w!=PIXY_START_WORD)
      return blockCount;
template <class LinkType> int8_t TPixy<LinkType>::setServos(uint16_t s0, uint16_t s1)
  uint8_t outBuf[6];
  outBuf[0] = 0x00;
  outBuf[1] = 0xff;
  *(uint16_t *)(outBuf + 2) = s0;
  *(uint16_t *)(outBuf + 4) = s1;
  return link.send(outBuf, 6);
#endif
hello_world.ino (1.12 KB)
Pixy.h (2.61 KB)
PixyI2C.h (1.03 KB)
PixyUART.h (1.16 KB)
kenneth619:
Not sure what you mean by "pull the variable out". If you mean "How do I assign the variables in the struct to other variables?", or "How to I test the value of the variables in the struct?", then it's simply a matter of using them like any other variable.
First, though, how did you manage to compile that code? Here's the right way to do that struct:
struct
  void print()
    char buf[64];
    Serial.print(buf);
  uint16_t x;
  uint16_t y;
  uint16_t width;
  uint16_t height;
} Block;
So, copy and paste the following into the IDE, run it, and see the result:
struct
  void print()
    char buf[64];
    sprintf(buf, "signature: %d, x: %d, y: %d, width: %d, height: %d\n", signature, x, y, width, height);
    Serial.print(buf);
  uint16_t x;
  uint16_t y;
  uint16_t width;
  uint16_t height;
} Block;
uint16_t sig;  // A global variable
  Serial.begin(115200);  //assign values to Block variables
  Block.signature = 1234;
  Block.x = 50;
  Block.y = 60;
  Block.width = 640;
  Block.height = 480;
  Serial.println(Block.signature); // print a Block variable
  sig = Block.signature;  // assign a Block variable to a global variable
  Serial.println(sig); // Prove we assigned it
  Block.print();  // use the function in Block to print all Block Variables
