Coding continues...
First part - to get setpoint values - is almost completed. But there's one big drawback. I would like to put all code concerning input of setpoint values in the setup part of the sketch. Tried different ways without success. Here are the premises:
I have 7 files on mSD, with different burning data.
One example file: RawGlaz.txt: 0,20,240,300,280,790,300,790,315,20,0,0
Would like to choose one of these files, to get the right time/temp relations for the actual burning.
By Serial.read I can choose file 1-7 and thus read the correct data in this file.
But I dont realize how to get "if (Serial.available())" working as expected in "void setup". I realise that one should find a method to delay and wait for an input, but I cant figure out how.
Right now this procedure is placed in the "void loop"-part of the sketch, and it works ok. But I would seriously avoid to open/close mSD-files everytime the process moves through the loop. Any clues?
Heres the code. Dont care for all prints, right now they're only checkpoint for me.
#include <SD.h>
//Declarations
char* BurnCurve[]={
"GLABEND.TXT", "RAWGLAZ.TXT", "DRYING_.TXT", "STOWARE.TXT", "STOGLAZ.TXT", "CLAGLAZ.TXT", "BISCUIT.TXT"};
int i, temp, time, tempArray[5], timeArray[5];
int incomingByte;
//Open serial comm. & set comm. channels
while (!Serial)
pinMode(10,OUTPUT);
if(!SD.begin(8))
Serial.println("initialization failed!");
return;
// Instructions to choose right Burn curve
for (i=0; i<7; i++)
Serial.print(BurnCurve[i]);
Serial.print(" - Choose ");
Serial.print(i + 1);
Serial.println(" for this curve");
// Input number of Burn curve
// read the incoming byte:
incomingByte = Serial.read();
incomingByte = incomingByte - 49;
Serial.println("");
Serial.print("Burn Curve is: ");
Serial.println(BurnCurve[incomingByte]);
File SPFile = SD.open(BurnCurve[incomingByte]);
Serial.println("");
if (SPFile)
for (int i=0; i<6; i++)
time = SPFile.parseInt();
temp = SPFile.parseInt();
tempArray[i] = temp;
timeArray[i] = time;
Serial.println("");
Serial.print(timeArray[i]);
Serial.print(" ");
Serial.println(tempArray[i]);
// if the file didn't open, print an error:
Serial.println("error opening RawGlaz.txt");
// close file:
SPFile.close();
Serial.println("done.");
Calculate SetPoint values from temp/time Arrays
Catch data from the thermocouples and transform to degrees centrigrade
PDI calculations
Output to thyristor stack
EOF
Here's the output when choosing file GlaBend.txt through sending "1" as input:
GLABEND.TXT - Choose 1 for this curve
RAWGLAZ.TXT - Choose 2 for this curve
DRYING_.TXT - Choose 3 for this curve
STOWARE.TXT - Choose 4 for this curve
STOGLAZ.TXT - Choose 5 for this curve
CLAGLAZ.TXT - Choose 6 for this curve
BISCUIT.TXT - Choose 7 for this curve
Burn Curve is: GLABEND.TXT
0 20
200 625
210 625
450 400
600 200
615 20
done.
