I'm going to show everyone just how much I don't know here.
Years ago I used to do some PLM coding for embedded applications. We would set up a structure using the 'dot' operator. For instance the definition would be:
define timer is (
start_count byte
timed_out boolean
counter byte);
then the instance would be:
general_timer type timer;
Then the usage would be:
general_timer.start_timer = 0;
general_timer.timed_out = false;
if (general_timer.counter > 1) then
begin
end;
. etc.
I may have some of that wrong since it was a BUNCH of years ago but hopefully you get the point.
My question is, can I do the same type thing with Arduino?? and how?
Thanks very much! It looks like the idea is exactly the same, just the syntax is a little different.
I found the 'struct' definition in the playground thingy. However, I couldn't find one for 'typedef'. I've seen that used in several places but don't know what it means. Is it required?
I'm finding that if I keep things elementary simple then I tend to not get confused as much. This C stuff is really cryptic.
I use my Arduino to control the temperatures in my two smokers during BBQ competitions. I absolutely LOVE showing my homemade controller to the guys who paid hundreds of $ for theirs. ;D
