Struggiling to make MPU6050 Temperature readings work
Hello, can anyone help with taking readings of temperature from an MPU6050 using Wire.h library. Im not allowed to use any other librarier.
I have gotten the Accelerometer to work but when I try to use the temperature module it just breaks and even the Serial port stops printing anything.
I have included Wire.h earlier in the code.
#define MPU_ADDRESS 0x68
int aX, aY, aZ;
int  tempL, tempH, tempOut;
float mpuTemp;
void AccelerometerModule() {
 //READING THE ACCELEROMETER DATA
 Wire.beginTransmission(0x68);
 Wire.write(0x3B);  // starting with register 0x3B (ACCEL_XOUT_H)
 Wire.endTransmission();
 Wire.requestFrom(MPU_ADDRESS, 6, true); // request a total of 6 registers
 aX = Wire.read() << 8 | Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
 aY = Wire.read() << 8 | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
 aZ = Wire.read() << 8 | Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
 Wire.beginTransmission(MPU_ADDRESS);      //Start communication with the MPU-6050.
 Wire.write(0x6B);                               //We want to write to the PWR_MGMT_1 register (6B hex).
 Wire.write(0x00);   //enable temp sensor
 Wire.write(0x41);
 //Wire.beginTransmission(MPU_ADDRESS);
 Wire.requestFrom(MPU_ADDRESS, 2, true);
 tempH = Wire.read() << 8 | Wire.read();
 tempL = Wire.read() << 8 | Wire.read();
 tempOut = (tempH | tempL);
 mpuTemp = (tempOut / 340.00) + 36.53;
//  if (aX > 15000) {
//    data = 'U'; // LANDSCAPE
//  if (aX < -13000) {
//    data = 'L'; // UPSIDEDOWN
//  if (aY > 14000) {
//    data = 'l'; // ROTATED RIGHT
//  if (aY < -14000) {
//    data = 'R'; // ROTATED LEFT
//  if (aZ > 11000) {
//    data = 'F'; // FLAT
//  if (aZ < -18000) {
//    data = 'B'; // BASE
Thank you very much!
Why not post the entire code?
Its a little long and alot of doesnt affect this particular code module.
But here it is.
//TASK LIST
//1. Resource Manager Finite State Machine (FSM)
//2. A multi-functional traffic lights controllerK
//3. Barrier crossing controller [DONE]
//4. Motor racing lights controller [DONE]
//5. A 3-colour LED controller [DONE]
//6. Two switch-debounce modules [DONE]
//7. A heartbeat module [DONE]
//8. A Tilt-Sensor and Thermometer based on the MPU6050
//9. A simple Command Interpreter[DONE]
//10. Scheduler(s)
#include <Wire.h>
const byte Characters[] = {
  0b01100000, //1 0
  0b11011010, //2 1
  0b00111110, //B 2
  0b10011110, //E 3
  0b10001110, //F 4
  0b00000001, //DP 5
  0b00011110, //t 6
  0b01111100, //U 7
  0b00011100, //L 8
  0b10000100, //I 9
  0b00000110, //R 10
  0b00000000  //OFF 11
unsigned long currentTime;
byte SegDSPL;
//==============================RGB FADE LEDS=====================================
#define RED 9
#define BLUE 10
#define GREEN 11
int color = 8;
int i = 0;
bool fade = false;
//====================================SW1 MODULE (MODE SELECT)====================================//
unsigned long SW1_LastDT = 0;
int SW1, SW1_State, SW1_lastState = 1, SW1flickState = 0;
bool Switch_1;
int Module = 0;
int Mode = 0;
int Trains = 0;
#define button1 A0
void switchTwo() {
  SW1 = digitalRead(A0);
  //unsigned long currentTime = millis();
  if (SW1 == LOW) {
    SW1_State = 0; // Replicating digitalRead() function.
  else {
    SW1_State = 1;
  if (SW1_State != SW1flickState) {
    // reset the debouncing timer
    SW1_LastDT = millis();
    // save the the last flickerable state
    SW1flickState = SW1_State;
  // Checks that the apporriate time has passed, basically a delay();
  if (((long)(currentTime - SW1_LastDT) >= 300)) {
    if (SW1_lastState == 1 && SW1_State == 0) {
      Switch_1 = true;
      Mode = Mode + 1;
      //Trains = Trains + 1;
    else {
      Switch_1 = false;
    SW1_lastState = SW1_State;
//====================================SW2 MODULE (MODULE SELECT)==================================//
unsigned long SW2_LastDT = 0;
int SW2, SW2_State, SW2_lastState = 1, SW2flickState = 0;
bool Switch_2;
#define button2 A1
void switchOne() {
  SW2 = digitalRead(A1);
  if (SW2 == LOW) {
    SW2_State = 0; // Replicating digitalRead() function.
  else {
    SW2_State = 1;
  if (SW2_State != SW2flickState) {
    SW2_LastDT = millis();
    SW2flickState = SW2_State;
  if (((long)(currentTime - SW2_LastDT) >= 300)) {
    if (SW2_lastState == 1 && SW2_State == 0) {
      Switch_2 = true;
      Module = Module + 1;
      //  Trains = Trains - 1;
    else {
      Switch_2 = false;
    SW2_lastState = SW2_State;
//===================================FSM MODULE===================================================//
#define GRANTED A2
#define GRANTED_H pinMode(GRANTED,INPUT_PULLUP);
#define GRANTED_L digitalWrite(GRANTED,LOW); pinMode(GRANTED,OUTPUT);
// State definitions
#define NoTriggerNoDemand    0   // idle state
#define TriggerIamMaster     1   // we are master after a successful claim
#define IamSlave             2   // we are slave after other device has made a successful claim
bool ACCEL = false;
bool TRIGGER;
int STATE;
int timingState, Counter;
char data, response;
unsigned long lastTime, lastTime_1 = 0;
//unsigned long currentTime;
void leaveHigh(unsigned char pin) {
  pinMode(pin, INPUT_PULLUP);
void pullLow(unsigned char pin) {
  digitalWrite(pin, LOW);
  pinMode(pin, OUTPUT);
bool demandREQ() {
  return (!(analogRead(A6) >> 8));
// function that executes whenever data is requested from master
void requestEvent() {
  Wire.write("ACK"); /*send string on request */
void receiveEvent(int howMany) {
  while (0 < Wire.available()) {
    data = Wire.read(); /* receive byte as a character */
    //Serial.print(data); /* print the character */
  //Serial.println(); /* to newline */
void FSM() {
  switch (STATE) {
    case NoTriggerNoDemand: //No trigger, No demand
      GRANTED_H;
      if (TRIGGER == true) {
        STATE = 1;
      else if (!TRIGGER && demandREQ()) {
        STATE = 2;
    case TriggerIamMaster: // I am master
      GRANTED_H;
      if (TRIGGER == false) {
        STATE = 0;
    case IamSlave: // I am Slave
      GRANTED_L;
      if (!demandREQ()) {
        STATE = 0;
  if (((long)(currentTime - lastTime_1)) >= 1) {
    TimerModule();
    lastTime_1 = currentTime;
void TimerModule() {
  switch (timingState) {
    case 0:
      timingState = 1;
      lastTime = millis();
    case 1:
        if (((long)(currentTime - lastTime)) > 17) {
          TRIGGER = true;
          timingState = 2;
        else {
          timingState = 1;
    case 2:
      if (STATE == TriggerIamMaster) { //State 1 is MASTER state
        timingState = 3;
      else {
        timingState = 2;
    case 3:
      receiveEvent(1);
      TRIGGER = false;
      timingState = 0;
//===================================HEARTBEAT MODULE=============================================//
unsigned long HB_LastTime = 0;
byte DP_ON_OFF;
void HeartBeatMod() {
  if (((long)(currentTime - HB_LastTime)) >= 500) {
    DP_ON_OFF = Characters[5];
  if (((long)(currentTime - HB_LastTime)) >= 1000) {
    DP_ON_OFF = Characters[11];
    HB_LastTime = millis();
//===================================BIT BANGING MODULE===========================================//
#define LATCH 13
#define CLOCK 12
#define DATA 8
void bitBang(unsigned char b) {
  for (int a = 0; a < 8; a++) {
    if ((b >> a) & (0x01)) {
      digitalWrite(DATA, HIGH);
    else {
      digitalWrite(DATA, LOW);
    digitalWrite(CLOCK, HIGH);
    digitalWrite(CLOCK, LOW);
  digitalWrite(LATCH, HIGH);
  digitalWrite(LATCH, LOW);
//==================================RGB LIGHTS====================================================//
int RGBLastTime;
void RGB(int R, int G, int B) {
  analogWrite(RED, R);
  analogWrite(GREEN, G);
  analogWrite(BLUE, B);
void ColorFade() {
  Serial.println(i);
  if (!fade) {
    if (((long)(currentTime - RGBLastTime)) > 4) {
      i++;
      if (i == 255) {
        fade = true;
      RGBLastTime = millis();
  if (fade) {
      i--;
      if (i == 0) {
        fade = false;
//===================================ACCELERMOTERE MODULE=========================================//
int aX, aY, aZ;
float mpuTemp;
  Wire.write(0x41);
//===================================ON OFF MODULE SORTING=========================================//
bool Equal = false, Set1 = false, Set2 = false, Maintenance = false, Crossing = false, Racing = false,
     ledOFF = false, Amber = false, Blue = false, Green = false, Red = false;
void sortingModule() {
  //----------------------------------- Traffic Lights ------------------------
  if (data == 0x61) {
    TrafficPriority(true);
    Equal = true;
    Set1 = Set2 = Maintenance = Crossing = Racing = false;
  if (data == 0x62) {
    Set1 = true;
    Equal = Set2 = Maintenance = Crossing = Racing = false;
  if (data == 0x63) {
    Set2 = true;
    Set1 = Equal = Maintenance = Crossing = Racing = false;
  if (data == 0x64) {
    TrafficPriority(false);
    Crossing = true;
    Set1 = Set2 = Maintenance = Equal = Racing = false;
  if (data == 0x65) {
    Maintenance = true;
    Set1 = Set2 = Equal = Crossing = Racing = false;
  if (data == 0x66) {
    Racing = true;
    Set1 = Set2 = Maintenance = Crossing = Equal = false;
  //----------------------------------- RGB Lights ------------------------
  if (data == 0x67) {
    RGB(0, 0, 0);
    Blue = Green = Red = Amber = false;
  if (data == 0x68) {
    Amber = true;
    Blue = Green = Red = false;
  if (data == 0x69) {
    Blue = true;
    Amber = Green = Red = false;
  if (data == 0x6A) {
    Green = true;
    Blue = Amber = Red = false;
  if (data == 0x6B) {
    Red = true;
    Blue = Green = Amber = false;
//====================================MULTIFUNCTIONAL TRAFFIC LIGHTS MODULES======================//
#define LEDS_OFF B00000000
#define LR B10000000//PIN7 R
#define LY B01000000//PIN6 Y
#define LG B00100000//PIN5 G
#define RG B00010000//PIN4 GG
#define RY B00001000//PIN3 YY
#define RR B00000100//PIN2 RR
//==============================BARRIER CROSSING=====================================
int T_barrierCrossing[] = { 5000, 500, 500, 500 };
const byte L_barrierCrossing[] = { LY | RY, LR | RR, LR, RR };
unsigned long mlastTime, clastTime, cArrayCounter;
int arrayCounter = 0, arrayCounter1 = 0;
unsigned long LS1, LS2, LS3;
const byte LightsSet1[] = { LY, LR, LR | LY, LG, LY, LR, LR, LR, LR };
const byte LightsSet2[] = { RY, RR, RR, RR, RR, RR, RR | RY, RG, RY };
int T_SET1[] = { 0, 2, 1, 1, 5, 1, 1, 1, 3, 1 };
int T_SET2[] = { 0, 2, 1, 1, 5, 1, 1, 1, 3, 1 };
void TrafficPriority(bool tfLights) {
  if (tfLights) {
    if (((long)(currentTime - LS1) > T_SET1[arrayCounter] * 1000)) {
      PORTD = LightsSet1[arrayCounter] | LightsSet2[arrayCounter1];
      LS1 = millis();
      arrayCounter = (arrayCounter + 1);
      if (arrayCounter >= 8) {
        arrayCounter = 0;
    if (((long)(currentTime - LS2) > T_SET2[arrayCounter1] * 1000)) {
      PORTD = LightsSet2[arrayCounter1] | LightsSet1[arrayCounter];
      LS2 = millis();
      arrayCounter1 = (arrayCounter1 + 1);
      if (arrayCounter1 == 8) {
        arrayCounter1 = 0;
//--------------------------------------------------Racing Lights-------------------------------//
#define r_idle 0
#define r_racing 1
#define r_finished 2
#define r_aborted 3
#define r_redflagged 4
int racing_aCounter, racingState;
unsigned long r_lastTime;
int r_Random = random(2, 6);
bool racingCount = false;
int r_Timing[] = {0, 1000, 1000, 1000, 1000, (r_Random * 1000) , 2000 , 500 , 500 };
const byte r_lightSet[] = {LR , LR | LY , LR | LY | LG , LR | LY | LG | RR ,
                           LR | LY | LG | RR | RY , LEDS_OFF , LG | RG
void racingLights() {
  //Display the letter F at all times whiles racing module is active.
  bitBang(Characters[4] | DP_ON_OFF);
  switch (racingState) {
    case r_idle:
      //Whilst in idle state all leds off;
      PORTD = LEDS_OFF;
      //A press of switch 1 will jump to racing state;
      if (Switch_1) {
        racing_aCounter = 0;
        racingState = r_racing;
    case r_racing:
      //The code for lights turning on in sequence
      if (((long)(currentTime - r_lastTime) > r_Timing[racing_aCounter])) {
        PORTD = r_lightSet[racing_aCounter];
        r_lastTime = millis();
        racing_aCounter = racing_aCounter + 1;
        if (racing_aCounter  == 8) {
          //When lights are finished set them to green and jump to finished state;
          PORTD = LG | RG;
          racingState = r_finished;
      //If switch 1 is pressed and the lights arent upto green yet jump to aborted state;
      if (Switch_1 && racing_aCounter <= 5) {
        racingState = r_aborted;
    case r_finished:
      //Both green LEDS always on whilst in the finished state
      PORTD = LG | RG;
      //When switch 1 is pressed, jump to redflagged state;
      if (Switch_1) {
        racingState = r_redflagged;
      //When switch 2 is pressed jump to idle state;
      else if (Switch_2) {
        racingState = r_idle;
    case r_aborted:
      //Whilst in aborted state, turn both yellow leds of and on for 0.5s;
      if (((long)(currentTime - mlastTime) >= 500)) {
        PORTD = LY | RY;
      if (((long)(currentTime - mlastTime) >= 1000)) {
        PORTD = LEDS_OFF;
        mlastTime = millis();
      //When switch 2 is presesd jump to idle state;
      if (Switch_2) {
    case r_redflagged:
      //Whilst in the redflagged state both red leds on, a press of switch 2 will jump to idle state;
      PORTD = RR | LR;
      if (Switch_2) {
//--------------------------------------------------Barrier Crossing-------------------------------//
#define b_idle 0
#define b_trainsPassing 1
int barrierState;
void barrierCrossing() {
  //Whilst this module is active, display b on the 7seg dsp;
  bitBang(Characters[2] | DP_ON_OFF);
  switch (barrierState) {
    case b_idle:
      //Whilst in this state, all leds off, a press of switch 1 will jump to trainsPassing state;
      PORTD = LEDS_OFF;
      if (Switch_1) {
        barrierState = b_trainsPassing;
    case b_trainsPassing:
      PORTD = L_barrierCrossing[cArrayCounter];
      if ((long)(currentTime - clastTime) >= T_barrierCrossing[cArrayCounter]) {
        cArrayCounter = cArrayCounter + 1;
        clastTime = millis();
        if (cArrayCounter == 4) {
          cArrayCounter = 2;
      if (Switch_1) {
      if (Switch_2 && cArrayCounter >= 1) {
      else if (Trains == 0) {
        cArrayCounter = 0;
        barrierState = b_idle;
void setup() { //-----------------------------------SETUP----------------------------------------//
  leaveHigh(GRANTED);
  TRIGGER = false;
  STATE = 0;
  timingState = 0;
  Wire.begin(8); /* join i2c bus with address 8 */
  Wire.onReceive(receiveEvent); /* register receive event */
  Wire.onRequest(requestEvent); /* register request event */
  pinMode(DATA, OUTPUT);
  pinMode(LATCH, OUTPUT);
  pinMode(CLOCK, OUTPUT);
  DDRD |= B11111100;
  pinMode(button1, INPUT_PULLUP);
  pinMode(button2, INPUT_PULLUP);
  pinMode(RED, OUTPUT);
  pinMode(BLUE, OUTPUT);
  pinMode(GREEN, OUTPUT);
void loop() { //-----------------------------------LOOP----------------------------------------//
  currentTime = millis(); // Main track of time used in all modules
  FSM();
  switchOne();
  switchTwo();
  HeartBeatMod();
  bitBang(DP_ON_OFF);
  sortingModule();
  if (Equal) { // Equal Priority
    bitBang(Characters[3] | DP_ON_OFF);
    T_SET1[4] = 5;
    T_SET1[8] = 3;
    T_SET2[4] = 5;
    T_SET2[8] = 3;
  if (Set1) { // Set 1 Priority
    bitBang(Characters[0] | DP_ON_OFF);
    T_SET1[4] = 7;
    T_SET1[8] = 7;
    T_SET2[4] = 5;
    T_SET2[8] = 3;
  if (Set2) {  // Set 2 Priority
    bitBang(Characters[1] | DP_ON_OFF);
    T_SET1[4] = 5;
    T_SET1[8] = 3;
    T_SET2[4] = 3;
    T_SET2[8] = 5;
  if (Maintenance) {  // Maintenance Mode
    bitBang(Characters[6] | DP_ON_OFF); // If maintenance mode 7SEG = t.
      PORTD = LY | RY;
      PORTD = LEDS_OFF;
  if (Crossing) {  // Barrier Crossing
    barrierCrossing();
  if (Racing) {
    racingLights();
  if (Amber) {
    ColorFade();
    RGB(i, i / 10, 0);
  if (Blue) {
    ColorFade();
    RGB(0, 0, i);
  if (Green) {
    ColorFade();
    RGB(0, i, 0);
  if (Red) {
    ColorFade();
    RGB(i, 0, 0);
  //AccelerometerModule();
 //Serial.println(mpuTemp);
 Wire.beginTransmission(0x69);      //Start communication with the MPU-6050.
  //----pointing temp sensor-----------------
  Wire.write(0x41);      //pointing Temp_Out_High Reg
  Wire.requestFrom(0x69, 2); //two-byte temp data from Temp_H and Temp_L
  byte x1 = Wire.read();
  byte x2 = Wire.read();
  int x = (int)(x1<<8)|(int)x2;
  //------compute temp from x-----
  float mpuTemp = (float)(x/340.0 + 36.53);  //formula from data sheets
  Serial.print("Temp = ");
  Serial.print(mpuTemp, 2);  //2-digit after decimal point
  Serial.println(" degC");
Check if the following sketch is useful for you only for acquring temp signal from MPU6050.
#include<Wire.h>
#define MPUaddr 0x68
  Wire.begin();
  Wire.beginTransmission(MPUaddr);
  byte busStatus = Wire.endTransmission();
  if (busStatus != 0)
    Serial.print("MPU is not found!");
    while (1); //wait for ever
  Serial.println("MPU is found");
  Wire.beginTransmission(MPUaddr);                        //Start communication with the MPU-6050.
  Wire.write(0x00);   //enable temp sensor                                           //Set the register bits as 00000000 to activate the gyro.
  Wire.write(0x41);      //pointing Temp_Out_High Reg                                           //Set the register bits as 00000000 to activate the gyro.
  Wire.requestFrom(MPUaddr, 2); //two-byte temp data                                  //End the transmission with the gyro.
  int x = (int)(x1 << 8) | (int)x2;
  float mpuTemp = (float)(x / 340.0 + 36.53); //formula from data sheets
Output:
Temp = 30.55 degC
Temp = 30.41 degC
Temp = 30.51 degC
Temp = 30.60 degC
Temp = 31.31 degC
Temp = 31.54 degC
Temp = 31.64 degC
Temp = 31.49 degC
Ive actually looked at this one before and It wasnt working for me, but you posting it got me thinking that maybe its the ESP, since its sharing the MPU with the arduino it has to be on for the MPU to work.
So thank you, I might actually make some progress here.
Which Arduino Board are you using? I have tested the sketch of post #4 in UNO.
Im using a nano, the serial printing works now, the fault was that both nano and esp have to be on. Now I just have to fix the code. Ill try some stuff from the example you sent.
