Hi, jimit here, I am experiencing struggle to get 50 hz position and velocity using imu and gps sensor, i use imu bmi270 and m8n gps, imu sensor has 50hz frequency and gps has 10hz frequency, i give you my ekf code, i built seprate algorithm for attitude estimation using quarternion, I have questions any preprocessing required to synchronise imu and gps data or ekf automatically do for me?
Here is my code
#include <INS/stateEstimation.h>
stateEstimation::stateEstimation(/* args */)
void stateEstimation::InitializeFilter()
prosessGpsInit();
gravity << 0.0f, 0.0f, -9.80665f;
proccessNoice(0, 0) = 0.2;
proccessNoice(1, 1) = 0.2;
proccessNoice(2, 2) = 0.3;
P.block(0, 0, 3, 3) = pow(P_V_INIT, 2.0) * Eigen::Matrix<float, 3, 3>::Identity();
P.block(3, 3, 3, 3) = pow(P_P_INIT, 2.0) * Eigen::Matrix<float, 3, 3>::Identity();
R.block(0, 0, 2, 2) = pow(SIG_GPS_V_NE, 2.0) * Eigen::Matrix<float, 2, 2>::Identity();
R(2, 2) = pow(SIG_GPS_V_D, 2.0);
R.block(3, 3, 2, 2) = pow(SIG_GPS_P_NE, 2.0) * Eigen::Matrix<float, 2, 2>::Identity();
R(5, 5) = pow(SIG_GPS_P_D, 2.0);
currentTime = micros();
void stateEstimation::getRotMat(Vector4f q)
float q0 = q(0), q1 = q(1), q2 = q(2), q3 = q(3);
rotMat(0, 0) = powf(q0, 2) + powf(q1, 2) - powf(q2, 2) - powf(q3, 2);
rotMat(0, 1) = 2.0f * (q1 * q2 - q0 * q3);
rotMat(0, 2) = 2.0f * (q1 * q3 + q0 * q2);
rotMat(1, 0) = 2.0f * (q1 * q2 + q0 * q3);
rotMat(1, 1) = powf(q0, 2) - powf(q1, 2) + powf(q2, 2) - powf(q3, 2);
rotMat(1, 2) = 2.0f * (q2 * q3 - q0 * q1);
rotMat(2, 0) = 2.0f * (q1 * q3 - q0 * q2);
rotMat(2, 1) = 2.0f * (q2 * q3 + q0 * q1);
rotMat(2, 2) = powf(q0, 2) - powf(q1, 2) - powf(q2, 2) + powf(q3, 2);
void stateEstimation::Update(float dt, Vector4f q, Vector3f accel)
getRotMat(q);
statePrev = state;
lpf_accel = 0.85f * lpf_accel + accel * 0.15f;
delVel = (rotMat * lpf_accel) + gravity;
accNavMag = delVel.norm();
state(0) = state(0) + delVel(0) * dt;
state(1) = state(1) + delVel(1) * dt;
state(2) = state(2) + delVel(2) * dt;
state(3) = state(3) + 0.5f * (state(0) + statePrev(0)) * dt;
state(4) = state(4) + 0.5f * (state(1) + statePrev(1)) * dt;
state(5) = state(5) + 0.5f * (state(2) + statePrev(2)) * dt;
for (size_t i = 0; i <= 2; i++)
state[i] = constrain(state[i], -5.0e2f, 5.0e2f);
// Constrain position to a reasonable vehicle range (in meters)
for (size_t i = 3; i <= 4; i++)
state[i] = constrain(state[i], -1.0e6f, 1.0e6f);
state[5] = constrain(state[5], -4.0e4f, 4.0e4f);
upDateCov(dt);
fuseGpsData(dt);
double posN = state(3);
double posE = state(4);
float posD = state(5);
converter.ned2Geodetic(posN, posE, posD, &newLatitiude, &newLongitude, &newAltitude);
newLocation(0) = newLatitiude;
newLocation(1) = newLongitude;
newLocation(2) = newAltitude;
void stateEstimation::upDateCov(float dt)
Fs.setIdentity();
Fs(3, 0) = dt;
Fs(4, 1) = dt;
Fs(5, 2) = dt;
Q(0, 0) = powf(proccessNoice(0, 0) * dt, 2);
Q(1, 1) = powf(proccessNoice(1, 1) * dt, 2);
Q(2, 2) = powf(proccessNoice(2, 2) * dt, 2);
Q(3, 3) = powf(proccessNoice(0, 0) * (dt * dt), 2);
Q(4, 4) = powf(proccessNoice(1, 1) * (dt * dt), 2);
Q(5, 5) = powf(proccessNoice(2, 2) * (dt * dt), 2);
// Q = 0.5f * (Q + Q.transpose());
P = Fs * P * Fs.transpose() + Q;
P = 0.5f * (P + P.transpose());
// Constrain velocity variances
P(i, i) = constrain(P(i, i), 0.0f, 1.0e3f);
// Constrain position variances
for (size_t i = 3; i <= 5; i++)
P(i, i) = constrain(P(i, i), 0.0f, 1.0e6f);
void stateEstimation::fuseData(Vector4f q, Vector3f accel)
if (GPS_ADD_COUNTER >= 0)
GPS_ADD_COUNTER--;
GpsDataAvailable = gps.processGPS();
if (GpsDataAvailable == gps.MT_NAV_PVT)
if ((byte)gps.ubxMessage.navPvt.fixType > 0)
SignalAvailable = true;
Lat = (double)gps.ubxMessage.navPvt.lat * 1e-07f;
Lon = (double)gps.ubxMessage.navPvt.lon * 1e-07f;
altitude = (float)gps.ubxMessage.navPvt.height * 1e-03f;
VEL_N = (float)gps.ubxMessage.navPvt.velN * 1e-03f;
VEL_E = (float)gps.ubxMessage.navPvt.velE * 1e-03f;
VEL_D = (float)gps.ubxMessage.navPvt.velD * 1e-03f;
NUM_OF_SAT = (int8_t)gps.ubxMessage.navPvt.numSV;
converter.geodetic2Ned(Lat, Lon, (float)altitude, &north, &east, &down);
actual(0) = VEL_N;
actual(1) = VEL_E;
actual(2) = VEL_D;
actual(3) = north;
actual(4) = east;
actual(5) = down;
GPS_ADD_COUNTER = 5;
NEW_GPS_DATA_COUNTER = 9;
NEW_GPS_DATA_AVAILABLE = 1;
digitalWrite(13, !digitalRead(13));
actual(0) = 0.0f;
actual(1) = 0.0f;
actual(2) = 0.0f;
actual(3) = 0.0f;
actual(4) = 0.0f;
actual(5) = 0.0f;
digitalWrite(40, !digitalRead(40));
NUM_OF_SAT = 0;
if (GPS_ADD_COUNTER == 0 && NEW_GPS_DATA_COUNTER > 0)
{ // If gps_add_counter is 0 and there are new GPS simulations needed.
NEW_GPS_DATA_AVAILABLE = 1; // Set the new_gps_data_available to indicate that there is new data available.
NEW_GPS_DATA_COUNTER--; // Decrement the new_gps_data_counter so there will only be 9 simulations
GPS_ADD_COUNTER = 5; // Set the gps_add_counter variable to 5 as a count down loop timer
// this bolow code run at 50Hz.
if (NEW_GPS_DATA_AVAILABLE)
if ((byte)gps.ubxMessage.navPvt.numSV < 8)
digitalWrite(13, LOW);
digitalWrite(40, LOW);
previousTime = currentTime;
dtGPS = (float)(currentTime - previousTime) / 1000000.0f;
Update(dtGPS, q, accel);
NEW_GPS_DATA_AVAILABLE = 0;
GPS_LOOP = true;
void stateEstimation::fuseGpsData(float dt)
currentTime = (float)micros();
dtGPS = (currentTime - previousTime) / 1000000.0f;
filteredGPSdt = filteredGPSdt * 0.95f + dtGPS * 0.05f;
actual(0) = VEL_N;
actual(1) = VEL_E;
actual(2) = VEL_D;
actual(3) = north;
actual(4) = east;
actual(5) = down;
error = actual - state;
float gpsVarianceScaler = filteredGPSdt / dt;
float velErr = 0.2f * accNavMag; // additional error in GPS velocities caused by manoeuvring
float posErr = 0.2f * accNavMag; // additional error in GPS position caused by manoeuvring
R(0, 0) = gpsVarianceScaler * powf(0.02, 2) + powf(velErr, 2);
R(1, 1) = R(0, 0);
R(2, 2) = gpsVarianceScaler * powf(0.006, 2) + powf(velErr, 2);
R(3, 3) = gpsVarianceScaler * powf(0.003, 2) + powf(posErr, 2);
R(4, 4) = R(3, 3);
R(5, 5) = gpsVarianceScaler * powf(0.0007, 2) + powf(posErr, 2);
S = H * P * H.transpose() + R;
K = P * H.transpose() * S.inverse();
state = state + (K * error);
P = P - (K * H * P);
// Serial.println(state(3));
actual(0) = 0.0f;
actual(1) = 0.0f;
actual(2) = 0.0f;
actual(3) = 0.0f;
actual(4) = 0.0f;
actual(5) = 0.0f;
NUM_OF_SAT = 0;
void stateEstimation::prosessGpsInit()
gps.gps_setup();
delay(4);
Lat = 0.0;
Lon = 0.0;
altitude = 0.0;
VEL_N = 0.0;
VEL_E = 0.0;
VEL_D = 0.0;
while (Lat == 0 && Lon == 0.0)
Lat = gps.ubxMessage.navPvt.lat * 1e-07;
Lon = gps.ubxMessage.navPvt.lon * 1e-07;
altitude = gps.ubxMessage.navPvt.height * 1e-03;
VEL_N = gps.ubxMessage.navPvt.velN * 1e-03;
VEL_E = gps.ubxMessage.navPvt.velE * 1e-03;
VEL_D = gps.ubxMessage.navPvt.velD * 1e-03;
delay(20);
converter = GeodeticConverter(Lat, Lon, (float)altitude);
state(3) = north;
state(4) = east;
state(5) = down;
state(0) = VEL_N;
state(1) = VEL_E;
state(2) = VEL_D;
#include <Arduino.h>
#include <ArduinoEigenDense.h>
#include <GPS/Geo.h>
#include <GPS/GPS.h>
class stateEstimation
private:
/* data */
public:
stateEstimation(/* args */);
GPS gps = GPS();
GeodeticConverter converter;
int8_t GpsDataAvailable;
bool isAvailable;
double north, east, down;
double Lat, Lon;
double VEL_N, VEL_E, VEL_D;
float altitude, accNavMag, newAltitude;
double newLatitiude, newLongitude;
double SIG_GPS_P_NE = 0.003; // 3.0
double SIG_GPS_P_D = 0.0007;
double P_P_INIT = 12.0;
double P_V_INIT = 1.0;
// GPS measurement noise std dev (m/s)
double SIG_GPS_V_NE = 0.02;
double SIG_GPS_V_D = 0.006;
VectorXf state = VectorXf::Zero(6);
VectorXf statePrev = VectorXf::Zero(6);
VectorXf stateNew = VectorXf::Zero(6);
Vector3f delVel = Vector3f::Zero();
Vector3f gravity = Vector3f::Zero();
MatrixXf P = MatrixXf::Identity(6, 6);
MatrixXf pHat = MatrixXf::Identity(6, 6);
MatrixXf pNew = MatrixXf::Identity(6, 6);
MatrixXf Q = MatrixXf::Identity(6, 6);
MatrixXf Fs = MatrixXf::Identity(6, 6);
MatrixXf H = MatrixXf::Identity(6, 6);
MatrixXf R = MatrixXf::Zero(6, 6);
MatrixXf K = MatrixXf::Zero(6, 6);
MatrixXf S = MatrixXf::Zero(6, 6);
Matrix3f proccessNoice = Matrix3f::Identity();
Matrix3f rotMat = Matrix3f::Zero();
Vector3d newLocation = Vector3d::Zero();
Vector3f lpf_accel = Vector3f::Zero();
void Update(float dt, Vector4f q, Vector3f accel);
void upDateCov(float dt);
void getRotMat(Vector4f q);
void fuseGpsData(float dt);
void fuseData(Vector4f q, Vector3f accel);
void InitializeFilter();
void prosessGpsInit();
void setPosition()
converter.setHome(Lat, Lon, altitude);
state(3) = north;
state(4) = east;
state(5) = down;
state(0) = VEL_N;
state(1) = VEL_E;
state(2) = VEL_D;
VectorXf error = VectorXf::Zero(6);
VectorXf actual = VectorXf::Zero(6);
int GPS_ADD_COUNTER = 0;
int NEW_GPS_DATA_COUNTER = 0;
int NEW_GPS_DATA_AVAILABLE = 0;
byte NUM_OF_SAT;
bool SignalAvailable = false, GPS_LOOP = false;
float currentTime, previousTime;
float dtGPS, filteredGPSdt;
Here how I use this algorithm
prevTimeIMU = currentTimeIMU;
currentTimeIMU = (float)micros();
dtIMU = (currentTimeIMU - prevTimeIMU) / 1000000.0f;
dtIMUFiltered = 0.85 * dtIMUFiltered + 0.15 * dtIMU;
estimation.Update(dtIMUFiltered, ekf.xhatNew, mAcc);
Ekf.xHatNew are the quarternion to get rotation matrix inside update function.
Assume that gps library i already built which give me 10hz location, and velocity data using ublox protocol and i already converted gps lat, lon to ned frame, you can already see, but I am struggling to get stable 50hz position estimation, i predict at 50hz and update at 10hz, I am not getting accurate results, can you help me friends, I am frustrated last 2 week, I spend two week for this algorithm, if I increase process noise i fase to much delay and if I decrease process noise I am not getting perfect 50hz data what should I do?
