Hi all, i am trying to do Fota in rp2040 using sim800l i am successfully able to download the .bin file but on restart my old firmware is running
my code is following
#define TINY_GSM_MODEM_SIM800
#include <TinyGsmClient.h>
#include <ArduinoHttpClient.h>
#include <PicoOTA.h>
#include <LittleFS.h>
#include <SoftwareSerial.h>
#define TINY_GSM_RX_BUFFER 1024
#define FILE_NAME "ota.bin"
// set GSM PIN, if any
#define GSM_PIN ""
// Your GPRS credentials, if any
const char apn[] = "www";
const char gprsUser[] = "";
const char gprsPass[] = "";
// Server details
const char server[] = "103.127.30.171";
const char resource[] = "/download/Blink.ino.bin";
const int port = 8080;
//// Server details
//const char server[] = "vsh.pp.ua";
//const char resource[] = "/TinyGSM/test_1k.bin";
//const int port = 80;
SoftwareSerial SerialAT(16, 17); // RX, TX
TinyGsm modem(SerialAT);
TinyGsmClient client(modem);
HttpClient http(client, server, port);
pinMode(25, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
delay(5000);
Serial.println("Rp2040 FOTA LittelFS Wait...");
if (!LittleFS.begin()) {
Serial.println("LittleFS Mount Failed");
if (checkFile(FILE_NAME))
if (removeFile(FILE_NAME))
Serial.println("File Deleted successfully");
} else
Serial.println("Unable to delete file");
} else
Serial.println("File Dose not exist");
SerialAT.begin(9600);
delay(6000);
// Restart takes quite some time
// To skip it, call init() instead of restart()
Serial.println("Initializing modem...");
modem.restart();
// modem.init();
delay(6000);
String modemInfo = modem.getModemInfo();
Serial.print("Modem Info: ");
Serial.println(modemInfo);
if (GSM_PIN && modem.getSimStatus() != 3) {
modem.simUnlock(GSM_PIN);
modem.gprsConnect(apn, gprsUser, gprsPass);
digitalWrite(25 , HIGH);
digitalWrite(10 , HIGH);
Serial.print("Waiting for network...");
if (!modem.waitForNetwork()) {
Serial.println(" fail");
delay(10000);
return;
Serial.println(" success");
if (modem.isNetworkConnected()) {
Serial.println("Network connected");
// GPRS connection parameters are usually set after network registration
Serial.print(F("Connecting to "));
Serial.print(apn);
if (!modem.gprsConnect(apn, gprsUser, gprsPass)) {
delay(10000);
return;
digitalWrite(11 , HIGH);
if (modem.isGprsConnected()) {
Serial.println("GPRS connected");
// Serial.print(F("Connecting to "));
// Serial.print(server);
// if (!client.connect(server, port)) {
// Serial.println(" fail");
// delay(10000);
// return;
// Serial.println(" OK");
// // Make a HTTP GET request:
// client.print(String("GET ") + resource + " HTTP/1.1\r\n");
// client.print(String("Host: ") + server + "\r\n\r\n\r\n\r\n");
// client.print("Connection: close\r\n\r\n\r\n\r\n");
// long timeout = millis();
// while (client.available() == 0) {
// if (millis() - timeout > 5000L) {
// Serial.println(F(">>> Client Timeout !"));
// client.stop();
// delay(10000L);
// return;
// Serial.println(F("Reading response header"));
// uint32_t contentLength = 67184;
// File file = LittleFS.open(FILE_NAME, "w");
// while (client.connected()) {
// String line = client.readStringUntil('\n');
// line.trim();
// Serial.println(line); // Uncomment this to show response header
// line.toLowerCase();
// if (line.startsWith("content-length:")) {
// contentLength = line.substring(line.lastIndexOf(':') + 1).toInt();
// } else if (line.length() == 0) {
// break;
// Serial.println(F("Reading response data"));
// timeout = millis();
// uint32_t readLength = 0;
//// CRC32 crc;
// unsigned long timeElapsed = millis();
// printPercent(readLength, contentLength);
// while (readLength < contentLength /* && client.connected() /*&& millis() - timeout < 10000L*/) {
// int i = 0;
// while (client.available()) {
//// uint8_t c = client.read();
// if (!file.write(client.read()))
// Serial.println("error writing character to LittleFS");
// readLength++;
// if (readLength % (contentLength / 13) == 0) {
// timeElapsed = millis() - timeElapsed;
// Serial.println();
// // Shutdown
// client.stop();
// Serial.println(F("Server disconnected"));
// modem.gprsDisconnect();
// Serial.println(F("GPRS disconnected"));
// float duration = float(timeElapsed) / 1000;
// Serial.print("Content-Length: "); Serial.println(contentLength);
// Serial.print("Actually read: "); Serial.println(readLength);
//// SerialMon.print("Calc. CRC32: 0x"); SerialMon.println(crc.finalize(), HEX);
//// SerialMon.print("Known CRC32: 0x"); SerialMon.println(knownCRC32, HEX);
// Serial.print("Duration: "); Serial.print(duration); Serial.println("s");
// Serial.println("starting Update after 3 seconds ");
// for (int i = 0; i < 3; i++)
// Serial.print(String(i) + "...");
// delay(1000);
Serial.print(F("Performing HTTP GET request... "));
int err = http.get(resource);
if (err != 0) {
Serial.println(F("failed to connect"));
delay(10000);
return;
digitalWrite(12 , HIGH);
int status = http.responseStatusCode();
Serial.print(F("Response status code: "));
Serial.println(status);
if (!status) {
delay(10000);
return;
Serial.println(F("Response Headers:"));
while (http.headerAvailable()) {
String headerName = http.readHeaderName();
String headerValue = http.readHeaderValue();
Serial.println(" " + headerName + " : " + headerValue);
int length = http.contentLength();
if (length >= 0) {
Serial.print(F("Content length is: "));
Serial.println(length);
if (http.isResponseChunked()) {
Serial.println(F("The response is chunked"));
File file = LittleFS.open(FILE_NAME, "a+"); // "w" opens the file for writing (if it exists)
if (!file) {
Serial.println("Failed to open file");
return;
String body = http.responseBody();
file.write(body.c_str(), 67512);
// Serial.println(F("Response:"));
// Serial.println(body);
Serial.print(F("Body length is: "));
Serial.println(body.length());
// Shutdown
http.stop();
file.close();
file = LittleFS.open(FILE_NAME, "r"); // "w" opens the file for writing (if it exists)
if (!file) {
return;
if (file) {
Serial.println("Reading");
while (file.available()) {
// Serial.println("iN FUNCTION");
uint8_t c = file.read();
Serial.print(c);
}else{
Serial.println("File Doesnot Exist");
file.close();
performFOTA(FILE_NAME);
delay(10000);
} else
return;
} else
return;
digitalWrite(10 , LOW);
digitalWrite(11 , LOW);
digitalWrite(12 , LOW);
LittleFS.end();
Serial.println("done\n\n");
Serial.printf("Rebooting in 5 seconds, should begin blinker instead of this app...\n\n");
delay(5000);
Serial.println("Restarting Device................\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n");
rp2040.reboot();
void performFOTA(const char* fileName)
Serial.printf("Programming OTA commands...");
picoOTA.begin();
picoOTA.addFile(fileName);
picoOTA.commit();
bool checkFile(const char* fileName)
// Check if the file exists
if (LittleFS.exists(fileName)) {
// File exists
return true;
// file dose not exist
return false;
bool removeFile(const char* fileName)
// remove exist file
if (LittleFS.remove(fileName)) {
// file removed successfully
Serial.println("File deleted successfully");
return true;
// failed to remove file
Serial.println("Error deleting file");
return false;
size_t getFileSize(const char* filename) {
File file = LittleFS.open(filename, "r");
if (!file) {
Serial.println("Failed to open file for reading");
return 0; // Return 0 if file cannot be opened
size_t fileSize = file.size();
file.close();
return fileSize;
void printPercent(uint32_t readLength, uint32_t contentLength) {
// If we know the total length
if (contentLength != -1) {
Serial.print("\r ");
Serial.print((100.0 * readLength) / contentLength);
Serial.print('%');
please suggest what wrong i am doing
