Struggling to get AVRISP mkii working with Mega2560
Hi all,
I know this has been covered in the past but I've found various conflicting bits of advice. I've built my own PCB for the Mega2560 and bought an (Olimex) AVRISP mkii to program it using Arduino IDE.
When trying to load the bootloader the IDE hangs indefinitely with the message 'Burning bootloader to I/O board(this may take a minute)...
Can someone firstly confirm these are the correct steps please and then perhaps advise on how to solve the problem.
-Installed libusb-win32 driver version 1.2.6.0 (verfied with device manager) -Plugged everything in -Tools>>board>>Mega -Tools>>programmer>>AVRISP mkii -Tools>>Burn bootloader
And then after that I can in theory 'upload using programmer' and I'm done, right?
So yeah...it hangs when trying to load the bootloader and if I try to upload sketch with programmer I get the following error.
All help appreciated, many thanks.
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : stk500v2
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200212345
avrdude: stk500v2_recv_mk2: error in USB receive
avrdude: stk500v2_getsync(): timeout communicating with programmer
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel STK500 Version 2.x firmware
         Programmer Model: AVRISP mkII
AVRISP mkII does not work with Arduino IDE due to a long-standing bug.
http://forum.arduino.cc/index.php?topic=345838.0
As a workaround, you can enable in preferences show verbose output on upload. The IDE may successfully run the first avrdude command and fail on the second command. Copy the second avrdude command to the command prompt on your computer and run it.
AVRISP MKii does work with the IDE, I have been doing so for 5+ years. In 1.0.6, search for the folder with avrisp2.inf 1.6.9 does not seem to include it, so the files may need to be installed from an older IDE. If Atmel Studio is installed, it used to install the Jungo driver (AS 5, don't know about current version) which didn't work with the IDE and some fooling around was needed. I found AS5 took forever to open, so I uninstalled it and never re-installed it when I got a newer computer.
CrossRoads:
If Atmel Studio is installed, it used to install the Jungo driver (AS 5, don’t know about current version) which didn’t work with the IDE and some fooling around was needed. I found AS5 took forever to open, so I uninstalled it and never re-installed it when I got a newer computer.
Thanks, I downloaded 1.0.5 and installed avrisp2.inf but no luck, error message pasted below. I’m using a genuine Arduino Mega board now to rule out potential problems relating to my PCB/dodgy soldering etc. Never had Atmel studio installed.
Could you please check and confirm your device manager looks like mine, I noticed what I installed is not digitally signed, is that normal?
Image here: https://postimg.org/image/5eel5iz13/
         Using Port                    : usb
Error while burning bootloader.
avrdude: usbdev_open(): did not find any USB device "usb"
Quirkologist: Thanks, I downloaded 1.0.5 and installed avrisp2.inf but no luck, error message pasted below. I'm using a genuine Arduino Mega board now to rule out potential problems relating to my PCB/dodgy soldering etc. Never had Atmel studio installed.
        Using Port                    : usb         Using Programmer              : stk500v2 Error while burning bootloader. avrdude: usbdev_open(): did not find any USB device "usb"
Read this Thread: IDE AVRISP
It shows what I had to do to solve the same problem.
Chuck.
Thanks Chuck but that didn't solve it either.
I worked out a solution though, for the benefit of anyone in the future- Make sure you have the correct firmware installed to the Olimex and use a version of Arduino IDE that uses AVRdude version 5, I'm on 1.0.5 now. It seems version 6 doesn't work with the Olimex AVRISP mkii.
Cheers all.
