Struggling with array over I2C serial communication
Im attempting to send an array between two Arduinos where I can change the values of the array. I am able to send an array between the two Arduinos, however the first section of the array which is variable does not change when the LDR value changes. Any ideas?
//sending
#include <SoftwareSerial.h>
SoftwareSerial mySerial(0,1); //rx pin,tx pin
int LDRPin = A1;
int a[]={1,2,3};
  mySerial.begin(9600);
  pinMode(LDRPin, INPUT);
  setArray();
  senddata();
void senddata(){
   int i;
   mySerial.print("<");
   for(i=0;i<sizeof(a)/sizeof(a[0]);i++){
      mySerial.print(a[i]);
      mySerial.print(",");
   mySerial.print(">");
void setArray(){
  a[0]=analogRead(LDRPin);
//receiving
char recvchars[32];
boolean newdata=false;
  recvdata();
  Serial.print(recvchars);
void recvdata(){
  static boolean recvinprogress=false;
  static byte ndx=0;
  char startmarker='<';
  char comma=',';
  char endmarker='>';
  char c;
  while(mySerial.available()>0 && newdata==false){
    c=mySerial.read();
    if(c==startmarker)recvinprogress=true;
    else if(c==endmarker){
      ndx=0;
      newdata=true;
    if(recvinprogress==true && c!=comma){
      recvchars[ndx]=c;
      ndx++;
Which Arduino boards are they ?
In your example code you're using Serial UART, not I2C. If you do in fact want to use I2C, take a look at this. If you want to use Serial/UART, use SerialTransfer.h (installable via the Arduino IDE's Libraries Manager).
@HXRRIETLXUGHXRNE1
Report to moderator is not the same as replying to the thread
