Struggling with Blynk to get global var value
Hi folks,
I am trying to get the value of a Blynk menu stored in a global var. Blynk works fine, I can see I get some feedback when I press the menu, but the global var is not updated.
Please find my code below :
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "xxx";
// Your WiFi credentials.
// Set password to "" for open networks.
const char* ssid = "xxx";
const char* password = "xxx";
int selected;
BLYNK_WRITE(V1){
  int selected = param.asInt();
  Serial.print("in blynk_write : ");
  Serial.println(selected);
  // Debug console
  Blynk.begin(auth, ssid, password);
  Blynk.run();
  Serial.print("in loop : ");
And here is what I get in the serial monitor :
[10400]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.6.1 on ESP8266
[10480] Connecting to blynk-cloud.com:80
[10560] Ready (ping: 17ms).
in loop : 0
in loop : 0
in loop : 0
in loop : 0
in blynk_write : 3
in loop : 0
Any idea ?
Can you be more descriptive of what "blynk" does and what it is supposed to do?
What does this class do and where did it come from?
param.asInt();
Are you trying to get input from the serial monitor? If so, your loop code doesn't show any action, except for Blynk.run(); of which, without information about what "blynk" does, we won't be able to help you.
  Blynk.run();
If you haven't already, please take some time to read the post about requesting help so that we can better assist you! :slight_smile:
Ok, my bad, thought Blynk was something well known in the iot community !
Blynk is something you can use with your ESP8266 to interact with. Basically, I installed the Blynk app on my phone, and configured a drop-down menu where I can select a value. I am trying to make a phone-controlled strip led. I would like to use Blynk to do so.
So, I want to get the selected value of that menu. The BLYNK_WRITE(V1) function does this. It sends the selected value to the Arduino. The param.asInt() retrieves the selected item from the menu as an int.
My thought was : I create a global var ("selected"), and I update it via this Blynk menu. Seems to work fine according to the serial monitor. BUT, when I log it in the loop, it doesn't seem to be the case.
I hope I cleared things !
you have a local variable which shadows the global variable
@Supernovali, if you don't know what Blynk is, simply don't comment
Hmmm, well, it's a bit awkward :confused:
I found the problem : as I am a total noob in C++, I've put a "int" before the var in the BLYNK_WRITE(V1) function. So, I guess, it creates a new variable everytime. No wonder it doesn't get updated.
Thanks for your help and patience, and I am going to slap my face gently now.
zouzou21:
Right, do a Google search for "variable shadowing".
Ok, dad. Trying to help someone here, but if you insist! Just kidding, I'm not afraid to ask for help or to try and help. I could learn something in the process. Hence, the creation of a forum.
Glad you were able to find the problem! And don't be afraid to ask questions! We should be a positive community! We can all learn something... Like right now, I am working on a project with MQTT for an IoT device so I might just have to look into blynk some more! Thanks :slight_smile:
