Struggling with first sketch in years
Once upon a time, I built a few Arduino projects and felt like I was progressing well.
Recently, I decided to have a crack at it again - I am spinning the simplest of projects, simply trapping some 433MHz rf code, and hopefully eventually posting the output to a Webservice of some sorts(probably just an ethernet shield and basic http post - or maybe, if I haven't pulled all my hair out yet, a quick post to MQTT)
I have managed to decode the RF signal (it's literally just a bit stream with a few binary values-but after a minute or two, my serial connection just dies.
I assume I am leaking memory somewhere, but I simply don;t know how to clean up.
Here is my code so far (it's ugly, I know - feel free to criticise, as long as it is constructive)
It was much prettier before I butchered it a thousand times and tried to dumb it down :frowning: - I started with this: http://arduinobasics.blogspot.com.au/2014/06/433-mhz-rf-module-with-arduino-
 const int dataSize = 256;  //Arduino memory is limited (max=1700)
 #define ledPin 13           //Onboard LED = digital pin 13
 #define rfReceivePin A0     //RF Receiver data pin = Analog pin 0
 const unsigned int upperThreshold = 100;  //upper threshold value
 const unsigned int lowerThreshold = 80;  //lower threshold value
 int maxSignalLength = 255;   //Set the maximum length of the signal
 int dataCounter = 0;    //Variable to measure the length of the signal
 void setup(){
 void loop(){
 byte storedData[dataSize];  //Create an array to store the data
  pinMode(ledPin, OUTPUT);
  while(analogRead(rfReceivePin)<1){
      //Wait here until a LOW signal is received
  digitalWrite(ledPin, HIGH);  //Turn LED ON
  //Read and store the rest of the signal into the storedData array
  for(int i=0; i<dataSize; i=i+1){
    //Identify the length of the LOW signal---------------LOW
    dataCounter=0; //reset the counter
    while(analogRead(rfReceivePin)>upperThreshold && dataCounter<maxSignalLength){
      dataCounter++;
    //Identify the length of the HIGH signal---------------HIGH
    dataCounter=0;//reset the counter
    while(analogRead(rfReceivePin)<lowerThreshold && dataCounter<maxSignalLength){
      dataCounter++;
    if(dataCounter < 100){
      if(dataCounter > 8){
        storedData[i]=1;
          storedData[i]=0;
      //Anything over 100 came from elsewhere, we'll tag this one 2...
      storedData[i] = 2;
    //Any readings between the two threshold values will be ignored.
    //The LOW or HIGH signal length must be less than the variable "maxSignalLength"
    //otherwise it will be truncated. All of the HIGH signals and LOW signals combined
    //must not exceed the variable "dataSize", otherwise it will be truncated.
    //The maximum number of signals is 1700 - if you try to extend this variable to a higher
    //number than 1700 - then the Arduino will freeze up and sketch will not work.
  //Send report to the Serial Monitor
 Serial.println("========GO=============");
  Serial.println("LOW,HIGH");
  delay(20);
  int start = 0;
   for(int n=0; n<dataSize; n=n+1){
    if(start <= 1 && storedData[n] == 1 && storedData[n+1] == 1 &&  storedData[n+2] == 0 &&  storedData[n+3] == 0 &&  storedData[n+4] == 0 &&  storedData[n+5] == 0 &&  storedData[n+6] == 0 &&  storedData[n+7] == 0){
      Serial.print("Found start");
      start = n;
      Serial.println(start);
      Serial.print ( storedData[n+17] + (storedData[n+16] * 2) + (storedData[n+15] * 4) + (storedData[n+14] * 8) + (storedData[n+13] * 16) + (storedData[n+12] * 32) + (storedData[n+11] * 64) + (storedData[n+10] * 128) + (storedData[n+9] * 256) +(storedData[n+8] * 512));
      Serial.print("F / ");
      Serial.print ( storedData[n+29] + (storedData[n+28] * 2) + (storedData[n+27] * 4) + (storedData[n+26] * 8) + (storedData[n+25] * 16) + (storedData[n+24] * 32) + (storedData[n+23] * 64) + (storedData[n+22] * 128) + (storedData[n+21] * 256) +(storedData[n+20] * 512));
      Serial.print("F");
//    Serial.println("====LOG======");
//  if(start >= 1){
//     for(int i=start; i<start+32; i=i+1){
//      Serial.print(storedData[i]);
//      delay(5);
  Serial.println("====FIN======");
Output goes like this:
641F / 1959F====LOG======
15:00:57.987 -> 11000000101000000121222122011111====FIN======
15:01:00.892 -> ========GO=============
15:01:00.939 -> LOW,HIGH
15:01:00.939 -> Found start262
79F / 77F====LOG======
15:01:00.973 -> 11000000000100111100000100110111====FIN======
15:01:06.890 -> ========GO=============
15:01:06.924 -> LOW,HIGH
15:01:06.924 -> Found start3
15:01:06.924 -> 79F / 77F====LOG======
15:01:06.958 -> 11000000000100111100000100110111⸮⸮==FIN======
15:01:13.976 -> ========GO=============
15:01:14.010 -> LOW,HIGH
15:01:14.010 -> Found start294
732F / 4F====LOG======
15:01:14.044 -> 11000000101100222011000000010010====FIN======
15:01:24.954 -> ========GO=============
15:01:34.216 -> LOW,HIGH
15:01:34.216 -> ====LOG======
15:01:34.250 -> ====FIN======
[color=black]15:01:34.250 -> O[/color]
Your program obviously violates the data array bounds. The result is unpredictable.
Hi and thanks - n is a second counter and given the depth of the dataset shouldn’t ever be beyond the upper bound - although I guess it is plausible - I’ll double check.
I’ve cleaned it up a little and moved the Serial.begin out of the loop and it seems less flakey.
This should not be in loop() either:
