Hi there,
just trying to implement a for loop to rotate a stepper motor using AccelStepper.h library. The very simple code we've written up is not working.
we are also using an l298N module with the Arduino to control and output the power supply. However, the wiring is working fine for the example code we've pulled from the internet, so its not a wiring issue.
OUR CODE
#include <AccelStepper.h>
#define DEG_PER_STEP 1.8 // could possibly change to increase speed of the motor
#define STEP_PER_REVOLUTION (360 / DEG_PER_STEP)
AccelStepper stepper(AccelStepper:: FULL4WIRE, 7, 6, 5, 4);
int stretch1Rotations = 11;
int stretch3Rotations = 33;
int stretch5Rotations = 55;
long moveToPosition = STEP_PER_REVOLUTION;
stepper.setAcceleration(200.0); // set acceleration
stepper.setSpeed(200); // set initial speed
stepper.setCurrentPosition(0); // set position to 0
stepper.moveTo(STEP_PER_REVOLUTION); // move motor one revolution, in clockwise direction
Serial.println("Motor moving in clockwise direction");
for (int i = 0; i <= stretch1Rotations; i++) {
Serial.print("Rotation no.: ");
Serial.print(i);
stepper.moveTo(moveToPosition);
Serial.print("rotation complete");
stepper.run();
EXAMPLE CODE USED AS REFERENCE
* Created by ArduinoGetStarted.com
* This example code is in the public domain
* Tutorial page: https://arduinogetstarted.com/tutorials/arduino-controls-stepper-motor-using-l298n-driver
AccelStepper stepper(AccelStepper::FULL4WIRE, 7, 6, 5, 4);
if (stepper.distanceToGo() == 0) {
Serial.println("Motor is stopped");
delay(5000); // stop 5 seconds
stepper.setCurrentPosition(0); // reset position to 0
moveToPosition = -1 * moveToPosition; // reverse direction
stepper.moveTo(moveToPosition); // move motor one revolution
if (stepper.distanceToGo() > 0)
else if (stepper.distanceToGo() < 0)
Serial.println("Motor moving in anticlockwise direction");
// Serial.print(F("position: "));
// Serial.println(stepper.currentPosition());
stepper.run(); // MUST be called as frequently as possible
pls help me why is it not working
